RW5 File Sample Needed
Andy Nold
(@andy-nold)
I am trying to salvage some data from a messed up data collector and set of handwritten notes and I haven't manually manipulated an RW5 file in about 4 years. Does anyone have a short, closed traverse in RW5 format so I can see how I need to format my data? Thanks in advance.
[email protected]
Posted : August 15, 2011 3:51 pm
DavidALee
(@davidalee)
If you are using Carlson, use the raw file editor and it formats it for you. Just make sure you have the HI first then the setup, HR then sideshots. Your setup info will be purple and your ss info will be blue, unless you are using dir-rev angles for a trav, then they will be brown, with a fd, fr, bd, or br at the front of the line.
Posted : August 15, 2011 3:59 pm
Andy Nold
(@andy-nold)
No Carlson at work. That would be easy. I did receive a sample file and I think I am just going to take it all home and enter into my Carlson on my home computer. This C3D editor is a royal pain in the kazoo.
Thanks for the samples.
Posted : August 15, 2011 4:21 pm
BigE
 BigE
(@bige)
I have one Andy.
It's on its way now.
E.
Posted : August 16, 2011 1:42 pm
