Robot/Reflectorless Opinion
(@bsulliv1)
Better choice: Leica TS13 or Geomax Zoom 90? long range BT, Plan to use Carlson RT4 controller with SurvPC
Posted : 01/02/2022 8:06 am
(@lukenz)
Robot hardware pretty much identical, plus your probably looking at a zoom95 which is nearly the same but with bigger screen onboard and faster processor as zoom90 has been replaced. I'd be asking myself which dealer I was buying from will have the best support. I've got a zoom 90 but running it with XPAD which is much nicer to use that SurvPC but depends if your using GNSS that needs SurvPC.
Assuming you will save some $$ with the geomax so appears a no brainer. As your probably aware Carlson also sell the geomax robots with their stickers on them.
Posted : 01/02/2022 9:55 am
(@ramses)
Definitely Zoom 90/95 which is in fact a TS15. You can use SurvCE/PC, Fieldgenius and Xpad with it. Great tracking and repeatable results with their ATR. Radio range is over 300m line of sight with the radio handle.
Posted : 02/02/2022 2:47 am
