Revisions to the Elevation Certificate
19 Users
john-putnam
(@john-putnam)
Or maybe make an editable Word document available.
Posted : November 20, 2017 9:05 am
andy-j
(@andy-j)
Steve D, post: 456455, member: 433 wrote: It may be that I am tech challenged. However: I would like to be able to save the document as a dead pdf document. When I attempt to print or save the document as a pdf it is still interactive. I can see some use for this, but would rather send my client a document that is not fillable.
I print it, sign it and scan that.
Posted : November 20, 2017 9:13 am
al
 al
(@al)
Photos are necessary. Sometimes I will annotate the images with data, comments and arrow and leader. Very useful. I believe it reduces the comments. I time stamp and also will include a survey equipment item in the photo.
Never have run into inquiries from desk jockeys. Inquiries have come from attorneys handling someone's interests or underwriters wanting a better picture so to speak of certain items. Inquiries from local FPAs are almost nil. They are competent and cooperative with the exception of some smaller jurisdictions where the FPA wears a few hats and have received minimal training.
Posted : November 20, 2017 9:43 am
I would never even consider releasing an editable electronic copy. Paper only.
Posted : November 20, 2017 2:57 pm
Steve D
(@steve-d)
Jim in AZ, post: 456621, member: 249 wrote: I would never even consider releasing an editable electronic copy. Paper only.
It is not much of a problem to scan any document, then convert it to a document that you can change, edit, or otherwise be dishonest with. I object to the present system because it allows unintended changes.
Posted : November 21, 2017 2:54 pm
Steve D
(@steve-d)
Jules J., post: 456456, member: 444 wrote: Print it as a pdf with a pdf printer. That will kill it.
That doesn't work for me. Adobe gives me an error message and refuses to play! Thanks for the thought.
Posted : November 21, 2017 2:56 pm
Renegade2438
(@renegade2438)
Great time for this.
They should have two lines for the flood vent areas. The current line A9c asks for Square Inches, which is ok if its just an opening in the enclosure, say a crawl space that has a screened opening.
When the openings are engineered vents, there should be a line to list the square "footage" of space the engineered vent covers. Now we have to put the "net free area" in Square Inches and it throws off the adjusters when the engineered vents do not have enough net free inches to cover the square feet of enclosure.
Posted : November 21, 2017 3:15 pm
Steve D, post: 456767, member: 433 wrote: That doesn't work for me. Adobe gives me an error message and refuses to play!
With Acrobat I save the PDF as a JPEG or other raster format, then open the raster file and save it as a PDF. That makes it as hard to modify as a scan of a paper copy.
Posted : November 21, 2017 6:54 pm
Lamon Miller
(@lamon-miller)
My comments to FEMA are as follows.?ÿ Dale I thought about including your comments but the certificate can be filled out in meters in PR.
1. Often we are asked to provide an EC before drawings are completed.?ÿ We call them a preliminary EC and we do them once I get something in writing from the owner stating they will comply with the elevation requirement of the parish or city.?ÿ The problem is we don't know the diagram no. so I type in NA and explain what is happening in the comments section.?ÿ A N/A option or similar would be helpful or a box with preliminary certificate where the diagram no. hasn't been determined.
2. Not often but several times I had a structure with both smart and regular vents because of additions to the original structure.?ÿ Being able to fill out both types would be helpful.?ÿ
3. As you know the EC contains 6 pages with the statement. "Copy all pages of this Elevation Certificate and all attachments for (1) community official, (2) insurance agent/company, and (3) building owner."?ÿ 90% if the certificates we do only pages 1,2 and 5 apply.?ÿ This means either we give out copies of blank pages or pages with NA or we state in the comments section we are only supplying pages 1,2 and 5 and 3, 4 and 6 don't apply.?ÿ We would like to eliminate the pages that don't apply if?ÿ possible.
4. I would like a place to stamp and sign each page with my seal.
Posted : December 18, 2017 3:43 pm
Skeeter1996
(@skeeter1996)
  • Where do you find the EC online entry form?
Posted : December 19, 2017 2:37 pm
Skeeter1996
(@skeeter1996)
Nevermind I dug it up finally.
Posted : December 19, 2017 2:38 pm
