> It would almost be worth doing the research and math to determine optimal size of wire and the tension required to keep 5800 feet of wire off the ground.
What the fence builder did was to pull the wire *over* a high point, tensioning the wire with a come-along, I'm sure. That method sort of works over shorter distances if you cut all the brush down and lift the wire at the high point to let it snap into place multiple times, gradually finding approximately the most direct line.
Over 5800 ft., and without a really good brushing job, it mostly just provided the *wrong* line to run the air hammer along, drilling the holes for the tee posts into rock.
I wouldn't rule out, though, that someone, somewhere is giving a seminar explaining that because an adjoining landowner didn't come dashing out to prevent the work with the rock drill that somehow the line was "established" in a position other than the one marked by the original stakes at either end of it. So, keep this in mind if there is a seminar in your future.
That's about what I figured based on how bad off they were.:-P
Reading further in ORS 672- Oregon
> 672.005 Additional definitions. .............
672.060 Exceptions to application of ORS 672.002 to 672.325.
ORS 672.002 to 672.325 do not apply to:
(8) A landowner performing land surveying within the boundaries of the landowner’s land or the landowner’s regular employee performing land surveying services as part of the employee’s official duties within the boundaries of the land of the employer.
(10) A person .... supervising the erection, enlargement or alteration of, a building, or an appurtenance thereto, ......
(11) A person making plans or specifications for, or supervising the erection, enlargement or alteration of, a building, or an appurtenance thereto,.....
(12) A construction contractor licensed under ORS chapter 701 that offers services constituting the practice of engineering if:
(a) The services are appurtenant to construction services to be provided by the contractor;
(b) The services constituting the practice of engineering are performed by an engineer or engineers registered under ORS 672.002 to 672.325; and
(c) The offer by the construction contractor discloses in writing that the contractor is not an engineer and identifies the engineer or engineers that will perform the services constituting the practice of engineering.
