Rebuilding your own batteries-
I saw last night that there is a website that sells the guts for battery re-builds-
Any of you use these/ done this?
http://www.sabahoceanic.com/epages/sabahoceanic.sf/en_us/?ObjectPath=/Shops/sabahoceanic/Products/29091001
This doesn't include Perry Williams' adventures with D cells and a chunk of 2x4....
Posted : July 27, 2010 1:13 pm
(@dave-ingram)
I used to rebuild my own bats, but I found out that Batteries Plus will do just as good a job and not cost much (if any) more than me buying the cells to do it myself. I qualify this by saying you want to be sure Batteries Plus has a good tech doing the work.
Posted : July 27, 2010 1:23 pm
Wendell
(@wendell)
Admin
Ditto that. I had several old Geodimeter horseshoe batteries rebuilt at Batteries Plus and they did a fine job. In fact, they were able to upgrade the batteries used from the old ones without having an impact on the voltage output. The horseshoes lasted about 6 hours after that and previously (before they needed to be replaced) were only good for about 4 hours.
Posted : July 27, 2010 1:48 pm
 jud
(@jud)
I have done my own with no problem. Just pay attention to the circuit, draw a sketch if you need to. Use rosin fluxed solder, not use acid fluxed and do not overheat. If you are not comfortable doing your own, send them in.
jud
Posted : July 27, 2010 2:02 pm
