RE: Trimble Site Calibration
1 Users
Skeeter1996
(@skeeter1996)
I call 481 a search point. 1360 is a found monument. If you do a one point calibration the whole job will move to that point and you can continue searching corners. When you find a second monument you calibrate to it and the entire project is rotated to the calculated positions basis of bearing. You continue searching monuments using the Stakeout routine for the calculated positions. You're now matched up with GPS positions and the old survey.?ÿ
As I understand your method, you would have to recalculate new search positions using your one found monument. Plus how do you ever calculate a somewhat close geographic location from an old metes and bounds survey?
Posted : April 30, 2018 11:07 am
