R= vs L= Quick Question
8 Users
Guest
I am a landowner and don't have any experience reading a survey plan. Could some one tell me what the actual frontage along the road is in regards to the attached small portion of our plan? Is it?ÿ L=167.25' or R=220.00' ? I assume it's 167.25" but I would greatly appreciate knowing for sure.
John / Airpix
plot plan question rR vs L
Posted : December 6, 2018 6:08 am
(@tim-reed)
L= Length of Curve, or Arc Length.
R= Radius of Curve.
Delta= Angular difference of the radial lines intersecting the two end points of the curve known as the PC (Point of Curvature) and PT (Point of Tangency)
167.25 is the lot frontage.
Posted : December 6, 2018 6:13 am
R=radius
L=length along the curve.
The triangle=delta=the included angle of the arc.
((43?ø33'24"/360)*440)*3.1416)=167.25'
Posted : December 6, 2018 6:16 am
Perhaps the most important thing for the owner to realize is that the frontage distance of 167.25' is measured along the arc.?ÿ If he stretches a tape from one front corner toward the other and measures the frontage distance, he's going to overshoot the other corner.?ÿ The chord (straight-line) distance is only 163.25'.
Posted : December 6, 2018 6:21 am
(@john-putnam)
Another quick heads up to the OP.?ÿ When surveyors work in feet it is conventionally annotated in decimal feet.?ÿ Thus the .25' = 3".
Posted : December 6, 2018 6:53 am
You guys jumped in very well on this. ?ÿHope the original poster understands now. ?ÿThe comment on the small difference, in this case, between the arc length and a straight-lined measurement is very important. ?ÿFor a very different radius the difference can be very important. ?ÿFor example, on a radius of 50 feet with a straight distance of 100 feet between the ends the arc length could be as much as 157 feet.
Posted : December 6, 2018 11:22 am
Posted by: holy cow
The comment on the small difference, in this case, between the arc length and a straight-lined measurement is very important.?ÿ
I wouldn't call 167.25 versus 163.25 a small difference.
Posted : December 6, 2018 12:39 pm
If you're buying it's huge, selling not so much...
Posted : December 6, 2018 1:22 pm
