Sorry didnt catch my error, with putting " behind the number behind the decimal point. Was tired and getting over a cold. Did not mean to state those numbers as if they were inches.
Posted : October 15, 2010 3:28 am
In my opinion the intent for your lot was for it to be 90 feet wide with parallel sides and perpendicular to the rear line. The record map appears to have two mapping errors in your lot. I believe the N41°48’38”E 5.44 line does not exist and the N47°15’43”E 95.58' line should be N47°15’43”E 90.15’. With this correction to the record map, all the lots in your block would be mathematically correct, however as others have said, the lot corners on the ground can very from the record plat.
Posted : October 15, 2010 9:24 am
Prev
