proper sizing of inverter
15 Users
(@dane-ince)
I am thinking of getting an inverter for my truck and I want to make sure that it will handle a jack hammer
thanks for your help
Posted : 13/02/2014 4:30 pm
Typically inverters have 2 110 outlets, 1/2 of inverter power going to each. I have never priced a 220 inverter. What is the surge requirement of your jackhammer?
I have a small inverter. It can handle a 16" electric chainsaw if the saw is sharp and I do not hog it in. I would like to know from anyone if one can merge the 2 110 outlets into a 220 (series) or 110 (parallel) with more amps.
A separate generator may cost less.
Posted : 13/02/2014 4:54 pm
(@dave-ingram)
You also need to think in terms of how much can your truck deliver to the inverter. Think in terms of input and output.
Posted : 13/02/2014 5:09 pm
I had a 750W model, once. It would just barely run a small hammer drill. A jackhammer, even a small one, will need 2000 watts or more. Check the label on the model you intend to buy.
Posted : 13/02/2014 5:11 pm
(@sir-veysalot)
Its gonna be a BIG inverter or a teeny tiny jackhammer.
Posted : 13/02/2014 6:26 pm
If I remember my 'tronicz class, this simple for-moo-la can help in deciding:
The power P in watts (W) is equal to the current I in amps (A), times the voltage V in volts (V):
P(W) = I(A) × V(V)
So watts are equal to amps times volts:
watt = amp × volt
sooo... a 120 volt drill motor that draws 2 amps is equal to 240 watts. I'm sure this formula is very basic. I bet that 'drill motor' probably draws twice as many amps under load as it's rating states.
Posted : 13/02/2014 6:33 pm
(@ridge)
Standard single phase power is two hots and a neutral. You get 120V between a hot and a neutral and 240V between the two hots. It's not a parallel of series like DC batteries. So if your inverter is built to provide two hots and a neutral you might get 240V. Check the voltage between the two hots of the two 120V outlets. Probably shouldn't use it that way at all if it wasn't built for that.
Posted : 13/02/2014 6:37 pm
I'd buy a Dodge 1500 or 2500 in that case, it will handle your jackhammer and the inverter.
Don't waste your time with GM products. Those electronics nightmares are one plug-in device away from an expensive mechanic shop bill.
Posted : 13/02/2014 6:38 pm
http://exeltech.com/products/inverters/inverters-2k-watt-icx-mcx/
You're also gonna' need at least a single ought set of leads to the battery. The inverter will draw some current.
Posted : 13/02/2014 6:49 pm
A lot depends on what you mean by "jackhammer." A 60-lb. Bosch Brute is going to draw a lot more than a 30-lb. demolition hammer. I own both, and each runs fine on a 2500-watt generator, but I don't know how much excess capacity -- if any -- I have with that setup.
Posted : 13/02/2014 6:55 pm
(@denny)
How bout a 2K Honda gen set
quite portable
does not way much
can use in on your cruiser also
or rv
Posted : 13/02/2014 7:08 pm
(@dane-ince)
Okay, once a year or so, I need to dig up a paved over monument. Typically a 1' sq of ac. This is all of five minutes work using power tools and I am tired of wrecking my elbows..... thanks for you comments i think a 2500 watt inverter will do just fine...
Posted : 13/02/2014 8:58 pm
For such occasional use,why not just buy a San Angelo bar for less than $20. Oh, and a pair of leather gloves? They do a great job on asphalt pavement and are simple to use. Would recommend. I'll find a photo of one so there is no miscommunication as to what is needed.
Posted : 13/02/2014 10:16 pm
I agree that power tools cost a lot and take up a lot of room in a truck, but once you've dug through hard AC with a demo hammer it's hard to go back to hand tools. I don't know about Texas, but here in California there are some AC mixes that are nearly as hard as concrete, and trying to get through them with a bar can take hours and beat up the (aging!) operator enough to make him spring for the power rig. It happened to me about 5 years ago, and I don't regret the purchase.
Posted : 13/02/2014 10:36 pm
Most stock alternators won't run a high density light bar much less anything that would need 2500 watts.
0.02
Posted : 13/02/2014 10:37 pm
