PLSSia lot numbering issue
Supporter Debater
The two photos below show the same area.  You may need to click on them to get a larger view.
The first photo shows the southern limit of what could be surveyed based on the New York Indians (general name--several different groups, actually) signing over their lands to the U.S. in the 1850's  The second photo shows the lands immediately to the south being surveyed based on the Cherokee Indians signing over their Neutral Lands to the U.S. in 1865.  The eastern edge of both transactions was the western border of Missouri.
In the first photo you can see that a narrow strip of land existed between the south line of Section 22 and the Indian Boundary that would be in Section 27.  Thus Lot 1 is in Section 27 south of the southeast quarter of Section 22 and the extended east line of that southeast quarter.  Lot 2 is in Section 27 south of the southwest quarter of Section 22 and the extended west line of that southwest quarter.
In the second photo you can see the vast majority of Section 27, except for the strip surveyed a dozen years prior and already known as Lot 1 and Lot 2.  The remainder of the north half of the northeast quarter is now labeled Lot 1 and Lot 2.  The remainder of the north half of the northwest quarter is now labeled Lot 3 and Lot 4.
Fortunately, the earlier Lot 1 and Lot 2 were purchased by the land owners directly north in Section 22.  But, other simiar sections to the east and west had cases where the owner of the land to the south in those sections also purchased the earlier Lot 1 or Lot 2.  When it came time to build a county road in the 1870's the road was laid out to follow the property lines rather than the section line or the Indian Boundary line.  For example, the road going east from the northeast corner of Section 27 goes one half-mile east, then drops the width of the earlier Lot 1 to the Indian Boundary and then goes east some distance before rising back to the section line to continue east.  Similar jumps in the road occur to the west as well.  The road crossing Section 27 is on the Indian Boundary.  Due to the sections to the south being surveyed a dozen years later the line extending north from the East and West quarter corners must connect to the existing corner set a dozen years earlier.  Thus, a "bend" normally occurs.  This is sometimes visible on north/south roads where the road follows the section line incluing the bend.
The confusion is that Section 27 and its neighbors have two Lot 1's and two Lot 2's.  Just for fun, consider the reality that different Special Instructions were in force for the earlier survey than for the later survey.
thumbnail file 42
thumbnail file 43
Posted : August 22, 2023 12:08 pm
aliquot
(@aliquot)
I assume you have done your due diligence here, but a warning to others:
Be careful, make sure  the field notes support the idea that the newer lines were bent to meet the older corners. In some of the townships like this the lines weren't bent and there are two sets of section corners. Many a surveyor has come to grief because they made assumptions that the situation was simpler than it really was.
Posted : August 24, 2023 7:01 am
Supporter
That's an unusual one, similar to the south line of the Ceded Strip which was early 1900's, but they did a much better job numbering those lots. They simply kept adding numbers as they added lines so there's no overlap.
I would look at patents first, find out if Lot 1 and Lot 2 were patented away between 1850 and 1865, that might solve it. Sounds like it doesn't since they jog the roads, implying that there's two distinct property lines.
Posted : August 24, 2023 7:33 am
Supporter Debater
They built the roads to match the property lines that had developed at that time (1870'S).  In the immediate area, anyway, that still holds true.  The skinny lots that are a half mile long are on the order of 150 to 160 feet wide.  Those numbers decrease, in general, as one goes to the east and wider to the west.
Not many miles to the west, that Indian Boundary meets the north end of a different Indian Boundary that runs south from there to Oklahoma.
If you what to witness this for yourself use the link below.  Go to the area for State and County and select Kansas (no need to select county)  Then go to the area for Land Location, for the area described above go to Township 26 South and Range 22 East.  Near the bottom of the page is the Search line that needs to be selected.  When the options for this township appear, you should have an 1859 option and an 1867 option.  The 1859 survey (field notes are much earlier than that) is north of the Indian Line.  The 1867 is to the south.
If you repeat this but slide west to Township 26 South and Range 21 East, you will find where the east west Indian Line hits the other Indian Boundary only going to the south.
https://glorecords.blm.gov/search/default.aspx#searchByTypeIndex=1&searchTabIndex=0
The junction of the Indian Lines occurs near 37.7589, -95.0755.  Pull that up on Google Earth/Maps.  Follow the jumps in Grand Road going to the east from there.  When the road is further north, it is following the section line.  When it drops back south, it is following the Indian Line.
Posted : August 24, 2023 11:24 am
