PLSS Township
11 Users
I came across this Township tonight while researching a nearby Township.
How much to retrace this puppy?
1 Section, 1 Lot, 7.75 acres = ONE TOWNSHIP!.
B-)
Posted : 14/01/2016 8:18 pm
$200
Posted : 15/01/2016 5:05 am
Loyal, post: 353331, member: 228 wrote: I came across this Township tonight while researching a nearby Township.
B-)
Are you? Retracing it?
Looks like fun, some closing corners, couple of mile markers, standard parallel.
Is that the best copy or a bad scan?
Posted : 15/01/2016 5:40 am
Isn't it Section 31?
Posted : 15/01/2016 5:46 am
(@j-penry)
Sometimes these little odd sections can have the best information or even monumentation because they were dealt with individually.
Posted : 15/01/2016 6:50 am
Mighty,
Utah BLM data on the Internet is (for the most part), scans of old microfiche. This one is not the sharpest tool, in a rather dull shed.
Yep, Section 31.
Nope, not this Township.
Posted : 15/01/2016 9:18 am
(@johnbo)
Will asume its sec. 31.
Very difficult to say. This is like going to the doctor with a lump and asking how much the operation is going to be. The doctor would say test, test, test and after the test, only an educate guess until I operate. The same with surveyors, when the research is done you can give an educated guess, and a lot of times its more of a guess then educated.
Just from the plat and assume all the corners are found. Retrace the exterior and retrace from the 82 MP to the 1/2 MP. This is a minimum, made without field notes and any research and could change wildly after your research and on the ground work.
GOOD LUCK
Posted : 15/01/2016 9:30 am
(@ric-moore)
simple right triangle. Can't you just do the math and intersect the lines?...duh! 😀
Posted : 15/01/2016 2:42 pm
B-)
"Section 31" is very readable.
The 7.75 Ac. refers to Lot 1 (the only lot) in Section 31.
Posted : 15/01/2016 2:56 pm
(@gene-kooper)
Piece of cake for an old hand like you Loyal. :whistle:
The trick is getting paid for all work required for a proper retracement.
Posted : 16/01/2016 9:35 am
(@bushwhacker)
At least you won't need to set the Center of Section.
Posted : 16/01/2016 9:52 am
Paul in PA, post: 353451, member: 236 wrote: "Section 31" is very readable.
Yes 31, I missread Loyal's post; had in my mind he was saying it was Lot 1 of a Section 1. My mental dyslexia at work.
Not sure why they didn't just add that Lot to Section 36 in the next township, there is probably a good reason. The reservation boundary clipped a lot of land if it takes out the rest of the township
As long as you do the work before you do the math it should be fun;^)
Posted : 16/01/2016 10:45 am
(@j-tanner)
Check Master Title Plat(s)? What is history of patents/entry in that area?
Posted : 16/01/2016 10:49 am
