Perplexing Day, Filed Maps and GPS Problems
5 Users
Not a major project but simply a swimming pool construction plan survey, I work for the pool installer.
I start out with PQ deed and filed map as referenced in PQ deed. PQ is last lot to West on Section A of development plan. Deed has minor variations from filed map and no comment as to why. Gather adjacent lot West deed and next section of development as referenced in adjacent deed. Filed map has notes it replaces a prior filed map and I find PQ deed is in agreement with that map information . OK, I can live with that certainty for a pool plan, were I doing an actual survey I would go to the courthouse rather than do on line research. Plot out PQ and adjacent lot each side and head off to the field for reconn and GPS.?ÿ
Check out the frontage for 2 lots each direction and get no sound, so I set mag in pavement (no curb) for an OPUS observation near SE corner. Set a mag in common driveway near SW corner for an L1 reference point. I am blocking the mailbox and as I set up the mailwoman arrives and I move Jeep into driveway. Finishing setup as PQ mom arrives and she waits for me to get out of driveway. She has no idea about corner pins, so I proceed with locator to back yard. All quiet on PQ corners. Neighbors to East had no recollection of corner pins. Mom to West comes home and thinks she saw one years ago in back yard. West dad comes home and yes, at the NW rear is a pin behind the shed. I grab locator and walk back, 3/4" rebar 1" up. As I flag it I recall that this is an angle point in filed plats, check plat and see a circle at corner but no calls. I will now get the previous plat. As I am putting locator away another neighbor walks by and asks what I am doing. I ask him where he lives and if he knows of any of his corner pins. He responds yes, because he had his lot surveyed. I ask him to show me some and we walk two lots West on far side of street. He shows me 2 old mag nails in pavement which appear to be on sidelines extended. He volunteers to show me his map and I ask if I can borrow it to copy. He says he can do better and brings up a 2011 pdf on his phone and shows me a mark up of part of the Filed Plat. He emails it to me on the spot. Back in the office the markups are in red ink and show 11 pins found, 1 metal detector reading in a driveway and 4 mags set and offsets from corners. He in fact owns back to back lots fronting two streets. This like gold to me. I set up to 2 more L1 units on those mags under trees but it is just for?ÿ orientation to get all filed plat info overlaying my orthoreferenced photo.
So I get home and download GPS and send off 2 hr 20 min file to OPUS. Worst data I have ever seen: 0.055m northing and 0.100m easting, but ortho height was 0.034m.?ÿ 67% of observations used and 36 of 63 ambiguities fixed. I can look North from the PQ and see the site where LUMT CORS sits, but that CORS was not used. I will download it and solve myself. As to my L1 receivers, positions were ridiculous, did I mention there were 50 year old street trees. L1 to L1 vectors used only 3 or 4 common satellites, so I excluded all L1-L1 and got relative position precision's under 0.010m. When I get back out there I can locate all 3 (plus any referenced pins I dig up) from my OPUS setup point and need to set 1 traverse in the back yard for the 3/4" rebar and the PQ pool area. Not in a rush as it is still snowing. Every setup leg point that was in lawn and not on pavement came out with a 3" clump of sod frozen to it when I broke down last night.
Today I will break my OPUS into 2 OPUS-RS files, plus see if OPUS picks any better CORS.
Perplexing to start, but hey, this is what makes surveying fun.
Posted : January 18, 2020 11:00 am
Posted by: @paul-in-pa
mags under trees
There are reasons the TS is not obsolete
Posted : January 18, 2020 12:18 pm
So I resubmit to OPUS, it chose 3 different CORS and things got worse: 0.092m northing and 0.441m easting, but ortho height was still 0.034m.?ÿ 64% of observations used but 39 of 62 ambiguities fixed. LUMT CORS was not available for a do it myself solution. I had also split for OPUS-RS, the first half gave a pretty solution the second half aborted. Shortened my OPUS to just under 2 hours and got pretty much the same solution, so I am going to go with that.
Also got the prior filed plat and the neighbor with the survey's deed. Now have a coordinate file to start with the EDM.
Interesting afternoon.
Posted : January 18, 2020 3:29 pm
You need some new gps gear. In my opinion.
Posted : January 18, 2020 4:38 pm
OPUS sometimes can be iffy, but I've never been stuck without being able to process to a CORS download unless it's too short a session, say 3-5 minutes for a CORS 30 miles away (or in heavy canopy), those can also be iffy.
What happens when you calculate it yourself?
Posted : January 19, 2020 1:05 pm
So I get home and download GPS and send off 2 hr 20 min file to OPUS. Worst data I have ever seen...
I've had trouble with results from OPUS within a few hours of collection. Try again the morning after. It may turn out significantly better.
Another thing is to exclude the bases used in your solution, forcing OPUS to select others.
Posted : January 19, 2020 1:45 pm
Today is Monday, local CORS data from Friday still not available on NGS site for downloading, so DIY not an option. I have assumed an alien spacecraft hovered over South Mountain Friday soaking up the GPS rays that should have gone to the CORS and my receiver. Anywho, it is 21?ø and heading up to 29?ø and will head out once I get brave enough. Last time out under these conditions the electrons froze in my EDM batteries. Will gather up my for GPS points, 10 street EP shots, house, shed and fence corners, one rebar and some ground/snow shots.
Posted : January 20, 2020 5:51 am
Paul,
If I lived closer, I'd come by, and shoot each point with javad, then, DPOS it. In 3 hrs, you'd have SPC all over.
But, I ain't up there. But, you could stand a demo.
Posted : January 20, 2020 7:16 am
