Party Chief Survey Software for HP48GX
7 Users
(@jmilam)
Yo. Anyone had any experience with "Party Chief Survey Software" and HP48GX?
Thanks,
Jim
Posted : August 10, 2012 5:15 pm
(@tom-wilson)
Yes, I have owned and used it for years. It is excellent, it has many very useful features and tools, extremely easy to use. It is my current go-to software for side calculations. It is a shame that they never moved on to newer platforms with it.
Actually it was makerted as RAMSS which is the company that wrote and sells it.
T.W.
Posted : August 11, 2012 4:15 am
(@carl-b)
TW
Also still use 48GX SMI Version 7. Do you know how to remove "Warning - Invalid Card Data"?. Only lasts about 2 seconds.
Carlton
Posted : August 11, 2012 7:40 am
 sinc
(@sinc)
It was pretty cutting-edge back in the mid-90's. But I can't imagine using it today, considering how much better you can do today.
Posted : August 11, 2012 8:02 am
PINIT Should Remove Warning
If it doesn't replace card battery.
If no battery keep fresh ones in HP 48 and turn it on on a regular basis.
Posted : August 11, 2012 8:28 am
(@jmilam)
Thanks, guys. I appreciate the info. Also, thanks to Paul in PA for the PINIT clue. I have also had that problem before and just "lived with it" as it goes away in a few seconds.
Thanks again,
Jim
Posted : August 11, 2012 8:56 am
(@jmilam)
> T.W.
Thanks, Tom. Do you know where I might obtain a User's Manual? RAMSS appears to have gone out of business???
Posted : August 11, 2012 9:37 am
(@retired-pls)
I have the manual and the software. Still working great
Posted : August 11, 2012 1:05 pm
(@jimmy-cleveland)
I have the Student Cogo version of the Ramss software, and on the same card is their Hydro Tools software. I bought that program
Card and 48GX when I was a draftsman and still in college. It is a great program, and I have used it for almost 17 years now.
Posted : August 11, 2012 1:11 pm
(@jmilam)
To: Retired PLS
Do you by any chance have a PDF version of Manual?
Thanks, Jim
jimmilam39@yahoo.com
Posted : August 11, 2012 1:51 pm
(@retired-pls)
The manual is in book form
Posted : August 11, 2012 2:12 pm
(@carl-b)
Thanks Paul
I haved tried PINIT and have replaced the card battery. Will keep trying, It may go away.
Carlton
Posted : August 12, 2012 3:50 am
(@tom-wilson)
Try http://www.ramss.com/
They still have a WEB site. I have always had excellent luck when dealing with these guys, but it has been many years sunce my last call.
T.W.
Posted : August 12, 2012 6:15 am
Reinitialize Then PINIT
Remove both cards.
Turn HP48 on with cards removed, now clear the 48 memory.
Hold down "On" Simultaneously press "A" and "F".
The diplay will show "Try to Recover Memory".
Press "No".
Wait, when you get all clear message, turn it off.
Open back, check to see that the 48 card contacts are clean, use a pencil eraser if neccessary. Blow out the dust.
Install both cards. Turn on, repeat the first steps.
Wait while the RAM card is initialized and the SMI card.
Reversing 2 of 3 batteries also clears memory.
Typing "PINIT" is the default, last resort is remove the foot and put a paper clip in the hole.
Hope it goes away. If not sacrifice a bucket from KFC. The 48 won't work better but you'll feel better.
Posted : August 12, 2012 6:41 am
