Opus message
5 Users
(@rberry5886)
Receiving this message more than once....doing a fast static on one control point...what's up with this?
FILE: 85041160.DAT OP1493210157145
1014 The RINEX data submitted to OPUS contains data taken from more than one
1014 location. This can be verified by opening up your RINEX file and
1014 searching for "MARKER". OPUS will only process data taken from one
1014 location. Try separating the data into individual files and then
1014 re-submit the data
1014 Aborting...
1014
Posted : April 26, 2017 4:38 am
use a text editor (not a word processor) to go through the rinex file (I use ultra edit) and look for "Comment" lines amongst the data lines. Remove them.
Posted : April 26, 2017 6:03 am
(@rberry5886)
Downloaded 30 day trial of ultra edit and I think I did what you said...either way still coming back from opus....maybe I'm removing too many lines or not enough....never had this problem before, although it has been awhile since I uploaded anything to opus...usually run on VRS network...and of course in TGO the points are processed usually geoid12B and could be off several feet. Trimble RTX had no problem and have X, Y, & Z, lat and long, and El. Height, which I'm taking to be Elipsoid Height, is this correct?
Posted : April 26, 2017 2:43 pm
(@scotland)
I get that error when I did two shots within the same file. You need to separate the shots. Someone more familiar with editing files will help you.
Posted : April 26, 2017 2:52 pm
(@rberry5886)
Each setup I did I changed job #s and cooked for 18 minutes, that's what has me confused....
Posted : April 26, 2017 3:09 pm
I use WordPad to open, read and edit RINEX files. A RINEX file is simply a text file.
I use Winteqc to check any RINEX file that OPUS rejects, it will let you know if it finds a new location marker and ask you if you want it removed.
I had one observation from yesterday rejected twice, my own editing did not work. Winteqc told me it found an error it could not fix, but tht file blew right through OPUS, 97% of observations used, 29/29 ambiguities fixed.
Posted : April 27, 2017 7:55 am
(@spledeus)
rberry5886, post: 425462, member: 232 wrote: Receiving this message more than once....doing a fast static on one control point...what's up with this?
1014 Aborting...
1014
Notepad++ works well too
Posted : April 27, 2017 5:14 pm
