OPUS and Topcon Hiper GA
9 Users
chaptech_rope_stretcher
(@chaptech_rope_stretcher)
Hi Folks,
I am using a Topcon Hiper GA (base and rover) setup. When uploading to OPUS...I do not see an option under "antenna type" for my GA's. Which antenna type should I be using. I HAVE been choosing TPSHIPER GGD...since it seeemd to fit my units the closest. Am I missing something...or should this give me what I need? Thanx
Jason
Posted : March 29, 2011 7:20 am
snoop
(@snoop)
I think a GA is in the same case as a Hiper Lite. Correct?
Posted : March 29, 2011 8:15 am
I suspect that the NGS simply hasn't "calibrated" this particular unit as yet (it's pretty new).
The KEY to getting good solutions, is using the RIGHT "antenna phase pattern data." This relates not only to the case configuration, but [more importantly] the the actual ANTENNA [patch, unit, model, whatever] installed in said case.
The Hiper GA appears to be a GPS + GLONASS unit (40 channel 10 or 20 hz), so I would suspect that the ANTENNA is similar to the HIPER Lite PLUS (also a 40 channel 10/20), but that is an ASSUMPTION! The fact that the GA has an central radio antenna (which the GGA doesn't), would make me lean towards the Hiper Lite PLUS (which does).
I would send an email off to Topcon, and see if you can get clarification on WHICH existent Phase Pattern model best fits the Hiper GA.
This is one of those things that I would NOT want to guess about!
Posted : March 29, 2011 9:04 am
RFB
 RFB
(@rfb)
After you do your homework, run an OPUS session on a known control point, or 4, with good elevations.
Then compare.
:coffee:
Posted : March 29, 2011 10:21 am
JerryS
(@jerrys)
The TPSHIPER_PLUS option is the correct one for what you have.
The HiPer+, HiPer Lite+, HiPer Pro, HiPer XT, HiPer Ga & Gb are all the same receiver differing in terms of the radio and the standard OAF file.
Posted : March 29, 2011 10:33 am
PerfectStranger
(@perfectstranger)
Has anyone found which OPUS antenna model best approximates the Hiper GA? I'm up against the wall with a ton of observations from a surveyor I contracted and he used the Hiper GA (Part Number: 01-860805-01 says he).
Thanks much,
Matt
Posted : August 23, 2011 1:59 pm
I just checked the latest IGS antenna file (igs08_1644.atx) and I didn'e see it there (could have missed I suppose).
See:
ftp://igs.org/pub/station/general/igs08.atx
I also looked at the latest NGS Absolute Calibration Files (see the Readjustment page), and no joy there either.
http://beta.ngs.noaa.gov/myear/
Beats me, it will be available when it's available I suppose.
Sorry,
Posted : August 23, 2011 3:24 pm
You might try
Just a thought, but you might shoot an Email off to Dr. Gerald Mader at NGS HQ.
[email protected]
He would probably know if that antenna is currently in the calibration pipeline, and if so when it might be available to OPUS.
Posted : August 23, 2011 3:37 pm
PerfectStranger
(@perfectstranger)
You might try
Thanks for the help and information. Much appreciated, my friend.
Regards,
Matt
Posted : August 24, 2011 5:26 am
sonofsurveyor
(@sonofsurveyor)
Opus and Topcon Hiper Ga/Gb
I have been using the Topcon Hiper Gb receivers and OPUS for the last 2 years. I contacted my equipment dealer who then contacted his Topcon Rep. to ask what Antenna Phase Center we should be using for the Hiper Ga/Gb receiver. He verified my choice which was the "TPSHiper Lite P/N 01-840802-03 Antenna+Receiver+Wireless".
Posted : February 14, 2012 2:10 pm
Denny
(@denny)
2 things using hiper sr and results from opus
are different then if iI use the same cors sites
by a fair amount. Not sure just yet because of the following
I put the 2 rtk receivers on
a initialization bar I had from
ashtech and shot as rover point
the horizontal difference was about 0.008 feet
close enough but the vertical was about 0.05 feet
which I suspected from some preliminary field work WTF
Posted : February 2, 2013 9:08 am
big-al
(@big-al)
In the picture below, taken from http://www.ngs.noaa.gov/ANTCAL/Antennas.jsp?manu=Topcon , take a look at the description text in the right most column. Does "GPS" indicate that the receiver tracks GPS satellites only, whereas "G/G" indicates that the receiver tracks both GPS and Glonass?
Posted : April 30, 2014 8:28 pm
I don't think so!
Here's the ANTEX record:
1.4 G ANTEX VERSION / SYST
A PCV TYPE / REFANT
This calibration extracted from composite ngs08.atx. See COMMENT
the composite file ngs08.atx for more information. COMMENT
END OF HEADER
START OF ANTENNA
TPSHIPER_PLUS NONE TYPE / SERIAL NO
FIELD NGS 3 25-MAR-11 METH / BY / # / DATE
0.0 DAZI
0.0 80.0 5.0 ZEN1 / ZEN2 / DZEN
2 # OF FREQUENCIES
IGS08_1788 SINEX CODE
CONVERTED FROM RELATIVE NGS ANTENNA CALIBRATIONS COMMENT
G01 START OF FREQUENCY
-0.22 1.23 87.75 NORTH / EAST / UP
NOAZI 0.00 -0.03 0.20 0.67 0.98 1.18 1.34 1.51 1.53 1.59 1.54 1.61 1.57 1.65 1.92 2.59 3.97
G01 END OF FREQUENCY
G02 START OF FREQUENCY
-0.78 0.11 89.45 NORTH / EAST / UP
NOAZI 0.00 -1.03 -1.61 -1.88 -1.89 -1.88 -1.79 -1.77 -1.91 -2.01 -2.05 -2.06 -1.83 -1.63 -1.33 -0.81 -0.05
G02 END OF FREQUENCY
END OF ANTENNA
Looks like an L1/L2 to me (# Frequencies 2).
Posted : April 30, 2014 9:16 pm
big-al
(@big-al)
Any clue what G/G means?
Posted : April 30, 2014 9:41 pm
No clue here...
Posted : April 30, 2014 10:10 pm
