Older Hiper Lite & Repeater
5 Users
hlb2
 hlb2
(@hlb2)
When the repeaters first came out my dealer warned me about my unit being too old for this service (something about me having the wrong serial #?). Does anyone know the reasoning behind this? Is there a way around it? I'd love to use one as my Hiper Lite is still kicking, but every now and then there's that 1 shot, or a couple of shots and you've got some radio issues. Any ideas?
Posted : May 20, 2015 9:39 am
hlb2
 hlb2
(@hlb2)
http://www.gpac.biz/tophpst.html?gclid=Cj0KEQiA5K-kBRDZ9r71gOvlxOMBEiQAwkK52BYEF9nMyseGCH9jq5COQF8aOE6QQ9r5f4_HraE0MuAaAlua8P8HAQ
I saw this in an older thread. Anyone use this? At 3.5m in length, is there any additional bracing needed on a standard tripod?
Posted : May 20, 2015 9:51 am
jimmy-cleveland
(@jimmy-cleveland)
I have a base/rover setup of 2002 vintage Hiper Lites. They works great.
I believe, if I understood Jerry Shearon of Hayes Instruments correctly, that there is a software limitation on the distance with the model that I have. I also believe that the low wattage, license free spread spectrum radios was also a limiting factor.
You might try contacting your dealer, or Hayes Instruments and see what they have to say.
Good luck. I'll be using mine until they won't work anymore!
Posted : May 20, 2015 10:49 am
antcrook
(@antcrook)
The older Hiper Lites have the FH915 radios on them. The RE-S1 repeater only uses the FH915+ when configured in repeater mode. You can have the radios in your Hiper Lite swapped out for the FH915+ and then it would work. You can still use the RE-S1 as an external radio by using the FH915 protocol, but that kind of defeats the purpose of having a repeater. I use it sometimes with my old legacy receiver and then I convert my Hiper Lite base to a rover and have two rovers running.
Posted : May 20, 2015 11:07 am
dmyhill
(@dmyhill)
I have a set of Hipers with the 915+ radios, how do I configure them as repeaters?
Is it pretty simple?
Posted : May 21, 2015 11:34 am
antcrook
(@antcrook)
You might be able to configure them using Modem-TPS.
Posted : May 21, 2015 11:44 pm
The Pseudo Ranger
(@the-pseudo-ranger)
You are correct that the Hiper Lites came with a software limitation of 1.5 or 2.5 miles, depending on age. That can be removed via an OEF upgrade for a price ... But unless its removed, you probably won't get much in the way of extended range from a repeater.
Posted : May 22, 2015 9:34 am
