NYSNET CORS and Mobile Mapper Office
(@matthew-m-filus)
Helping out a friend in New York with post-processing some Mobile Mapping data out of a Promark 3 in Mobile Mapper Office. The raw data in the Mobile Mapper Job file is fine and the time on points is correct.
However, when I bring in Rinex 2.11 data from NYSNET (1-second epoch), the time on point for each point gets all messed up and trimmed back.
Anyone have similar issues? Is it the Rinex version?
Thanks,
Matt
Posted : June 22, 2012 6:07 pm
(@leegreen)
No, I never had that problem. Try setting the epoch to 10 seconds via UFCORS when selectung data set. Doubt you would need 1 second epochs.
Are you using Topcon Tools to retrieve your cors data?
Lee Green
BTW. Did you ever sell the Hiper Lite
Posted : June 24, 2012 1:17 am
(@farsites)
Should not be a problem, but if you suspect Rinex version, open up a Rinex file in a text editor and simply change the 2.11 to 2.10 at the top of the file, save and see if it takes it. Worth a try.
Posted : June 24, 2012 12:03 pm
(@matthew-m-filus)
> Lee Green
Lee,
Tried UFCORS too and same deal. Thanks for the idea though. Yes, sold one of the Hipers and running the other VRS.
Matt
Posted : June 24, 2012 5:16 pm
(@matthew-m-filus)
Gave this a go too with no resolution. Thanks, Matt
Posted : June 24, 2012 5:17 pm
Have you brought in the same data via NGS ufcors?
Check if the RINEX format is different.
Posted : June 24, 2012 7:40 pm
(@matthew-m-filus)
Paul,
Yes, brought in data from the same CORS via UFCORS, same result. UFCORS was 2.10, NYSNET 2.11...
Thanks,
Matt
Posted : June 25, 2012 3:27 am
As an aside I registered with NYSNET just to compare data. Still waiting. So I grabbed an hour of data from NYHB from ufcors and was surprised to see I could not get 1 second data.
BTW. there are way too many comments in the NGS file header. As I recall a RINEX file header only requires 4 or 5 lines of data. Years ago I kept removing header data until OPUS would not accept it. That info is somewhere in the archives on the other board.
I would try removing the file splice comments from the data.
Posted : June 25, 2012 3:38 am
