Now What ?
13 Users
My screws finally rattled loose yesterday.
This comes from the ATV vibrations.
I am considering just re-attaching with some sort of epoxy.
Your thoughts ?
Posted : November 15, 2012 8:24 am
(@djames)
put a nut on the other side with a washer .
Posted : November 15, 2012 8:39 am
(@pin-cushion)
J.B. Weld
Posted : November 15, 2012 8:40 am
(@kris-morgan)
put a nut and washer on the other side.
Posted : November 15, 2012 8:54 am
(@stephen-ward)
Make it a lock nut or add Loctite to it.
Posted : November 15, 2012 9:42 am
 jaro
(@jaro)
Red Loctite should work, that's what it's made for. Use blue if you think you might need to take it apart again.
James
Posted : November 15, 2012 10:14 am
 BigE
(@bige)
Ditto that. Don't JB Weld it. You would never get them/it out if need be.
Loctite is un-doable with enough elbow grease. Not with JBWeld.
A lock washer should work. Maybe just wrap the screws in plumbers Teflon tape or the Teflon goo.
Posted : November 15, 2012 10:17 am
(@doug-crawford)
> James
I would use the 'blue'.
DWC
Posted : November 15, 2012 10:27 am
 jud
(@jud)
Looks like there is room inside for screw heads, I would get a piece of strap steel, drill holes at the proper spacing, grind a little off of the screw heads if needed and put it back together using the steel strap as a washer and use lock tight. You could use a chisel to make a burr on the screw edge and strap as a lock, "old school before lock tight".
jud
Posted : November 15, 2012 10:28 am
(@cptdent)
There's nothing that cannot be "fixed" with Super Glue and/or Duct Tape !! 😉
Posted : November 15, 2012 1:06 pm
(@stephen-johnson)
you forgot "Bailing War" AKA Baling Wire.
Posted : November 15, 2012 1:27 pm
 jud
(@jud)
Dad hired an old gentleman in the early 50's to run a Holt steel wheeled combine, evolved into the John Deer 36, still have the machine but don't know where the header went. His supply list required bailing wire and bacon rind. That machine had babbit bearings, hence the need for bacon rinds.
jud
Posted : November 15, 2012 1:39 pm
Baling, dammmmit, baling. Bailing involves a bucket and a sinking boat.
Sorry. One of my pet peeves. Sort of like there, their and they're. Misuse causes teeth gritting.
Posted : November 15, 2012 4:56 pm
 jud
(@jud)
If that is all you have to worry about, grit away.
jud
Posted : November 16, 2012 7:55 am
Problem Solved
Posted : November 16, 2012 11:57 am
Problem Solved
Good thinking. You probably should seal up the holes with some epoxy or even just some tape to keep crap and corruption from getting inside.
Posted : November 16, 2012 1:44 pm
Problem Solved
:good:
Posted : November 16, 2012 1:53 pm
