Newsflash: OPUS Continues to Work Great
13 Users
(@lee-d)
MightyMoe, post: 428697, member: 700 wrote: not every point gets 4 plus hours of set on time
Exactly. With the density of CORS in southeast Louisiana, I can get very good results with occupation times as short as ten minutes (not that I make a habit of that). Even in places like West Texas where the CORS are less dense, I can get extremely tight results with 2 - 3 hour sessions - exactly the occupation times that OPUS often struggles with.
Posted : May 17, 2017 4:50 am
Lee D, post: 428700, member: 7971 wrote: Exactly. With the density of CORS in southeast Louisiana, I can get very good results with occupation times as short as ten minutes (not that I make a habit of that). Even in places like West Texas where the CORS are less dense, I can get extremely tight results with 2 - 3 hour sessions - exactly the occupation times that OPUS often struggles with.
I've been processing 3 minute PPK sessions against CORS 30 miles distance and getting good results. The idea of setting on every point for 4-8hrs is a no go of course. No problem collecting that type of data for a base/rover on the base since it's sitting there anyway, but taking OPUS data on each point is just a time waster.
Often times the PPK session won't process to a far away base, but it doesn't hurt to give it a go when the CORS point is sitting there in the file anyway.
I recently had a 70 minute setup, I processed it to three CORS points (20mi, 95mi, 140mi), no problem, RTX wouldn't look at it, you couldn't even check the box.
Posted : May 17, 2017 5:18 am
(@mattharnett)
I've been using OPUS more and more lately. It's a great free lunch.
Posted : May 17, 2017 7:53 am
(@larry-scott)
mattharnett, post: 428732, member: 6458 wrote: I've been using OPUS more and more lately. It's a great free lunch.
And if you only one, older receiver you're not even in deep.
Posted : May 17, 2017 8:03 am
Page 3 / 3
