New height determined for Denali by USGS
7 Users
(@geeoddmike)
http://www.usgs.gov/blogs/features/usgs_top_story/new-elevation-for-nations-highest-peak/?from=title
The ten-foot difference is attributed to improved measurements not geophysical changes.
Some nice photos in this article as well as here: http://www.usgs.gov/newsroom/article.asp?ID=4312#.VfAVP8T3arV
BTW, the radar survey height which prompted this determination was found to be inaccurate.
Posted : September 9, 2015 3:15 am
(@dan-patterson)
Denali? You mean Mount McKinley?
Posted : September 9, 2015 3:22 am
(@john-giles)
Now all those people that have climbed it have to go back and climb that extra ten feet.
Posted : September 9, 2015 3:25 am
Dan Patterson, post: 335605, member: 1179 wrote: Denali? You mean Mount McKinley?
Apparently Denali is ten feet higher than McKinley.
Posted : September 9, 2015 3:30 am
(@geeoddmike)
The new height is ten feet LOWER...
Posted : September 9, 2015 4:01 am
(@john-giles)
Well I misread that one. Dang it.
Now they have to dig a 10' hole at the base and climb down into it I guess.
Posted : September 9, 2015 4:06 am
GeeOddMike, post: 335609, member: 677 wrote: The new height is ten feet LOWER...
Apparently the weight of the naming controversy has taken its toll on the mountain.
Posted : September 9, 2015 4:08 am
(@davis118)
I feel sorry for the surveyor that used any monuments to bench for an elevation. If FEMA sees this, everything is in a flood zone.
Posted : September 9, 2015 4:36 am
GeeOddMike, post: 335604, member: 677 wrote: http://www.usgs.gov/blogs/features/usgs_top_story/new-elevation-for-nations-highest-peak/?from=title
It has to be asked, what will the "new" adjustments do to this elevation?
Posted : September 9, 2015 5:10 am
(@geeoddmike)
The links below are (respectively) an image of the changes to ellipsoid heights, a presentation on the state of the vertical network in Alaska, a file on height issues in Alaska and an image of the USGG geoid-ellipsoid separations in Alaska.
http://www.ngs.noaa.gov/heightmod/AK20107ProbsWVerticalRefFrameIn0AKOppegard.ppt
http://www.ngs.noaa.gov/heightmod/201404KinsmanNGShtModernizationForOnline.pdf
Posted : September 9, 2015 5:53 am
GeeOddMike, post: 335619, member: 677 wrote: The links below are (respectively) an image of the changes to ellipsoid heights, a presentation on the state of the vertical network in Alaska, a file on height issues in Alaska and an image of the USGG geoid-ellipsoid separations in Alaska.
It looks like Alaska will get about a 1.5' increase in ellipsoid heights, will the geoid models get a 1.5' decrease or will that be independent of any ellipsoid changes?
Posted : September 9, 2015 9:21 am
(@geeoddmike)
My reading of the contours shows the differences in ellipsoid heights to range from 0 meters in SE, +0.5m in the middle, and +1.0 m in the Aleutians.
The changes to ellipsoid heights should be dominated by translation changes (origin differences). Doing a quick calculation using the itrf96 to nad83 translations (Tx = 0.991, Ty = -1.9072, Tz =-0.5129), I see the about 0.4 m at a point in Denali Borough.
The geometric geoid should be independent and not "contaminated" by the "inseparability" problems posed by data like the GPS on BM data.
Posted : September 9, 2015 10:50 am
GeeOddMike, post: 335680, member: 677 wrote: My reading of the contours shows the differences in ellipsoid heights to range from 0 meters in SE, +0.5m in the middle, and +1.0 m in the Aleutians.
At the end of the day, there will be new ellipsoid heights and a totally new Geoid Model, based completely on gravity measurments, at least I think that's the plan, and although the land at Denali will have a rise of .4m it may still have the same elevation. Or it may grow again;-)
Posted : September 9, 2015 11:58 am
(@dmyhill)
You only call it that if you are from Outside.
Posted : September 10, 2015 7:59 am
(@dan-patterson)
I was joking and I call it that in honor of President William McKinley.
Posted : September 10, 2015 8:34 am
