NAD83(2011)
25 Users
(@jwdenney)
I'm using an R6-2 rover & TSC3 w/Trimble Access on the Western Data Systems VRS network, which broadcasts NAD83(2011) adjustments. I've downloaded, and can use, the Geoid12A file, but if I wanted to use a stand-alone base, where can I download the NAD83(2011) datum file? My TSC3 currently only has the NAD83(Conus)(Mol).
Thanks in advance for your help.
Posted : 28/07/2014 1:35 pm
NAD83(CONUS) Molodensky has transformation parameters of 0,0,0.
You do not need any other file as long as you put a NAD83(2011) coordinate in for your base.
Posted : 28/07/2014 1:43 pm
(@jwdenney)
What if I don't have a NAD83(2011) coordinate for my base?
Posted : 28/07/2014 2:56 pm
(@shawn-billings)
what coordinate do you have for your base?
Posted : 28/07/2014 3:03 pm
(@jwdenney)
I take an autonomous reading when the job begins. If I have the NAD83(Conus)(Mol) datum in my data collector won't I have just a NAD83 coordinate for my base?
Posted : 28/07/2014 3:11 pm
then you will have a WGS84 position ± a few meters. Since the transformation is 0,0,0 that is what you will have. Not worth the trouble to transform n autonomous position from WGS84 to NAD83, as the accuracy of your position is probably less than the transformation.
Posted : 28/07/2014 3:15 pm
(@jwdenney)
I get what you're saying.
Just for curiosity's sake, is there a good paper/article on the actual transformation from NAD83 to NAD83(2011), and maybe a piece of software that can be used to perform the transformation?
Posted : 28/07/2014 3:31 pm
This page provides transformation parameters between NAD83 and IGS08 (the IGS version of ITRF2008), which itself is coincident with WGS84(G1674) at the centimeter level per this page.
Posted : 28/07/2014 4:36 pm
NAD 83, NAD83(86), NAD83(93), NAD83(2011) are just NAD83 updated to more "accurate" coordinates, it's important to know the Epoch that you're in cause there ever so small changes to the coordinates of points on the earth, and they are changing also because of drift.
So it isn't so much a conversion between systems such as NAD83 and WGS84.
When you set your Trimble up with NAD83 you get NAD83(2011) from your control so you are NAD83(2011). The control controls that, you can't just start your receiver and be on it.
Posted : 28/07/2014 4:48 pm
NAD83 realizations are tied as best possible to fixed positions on the North American tectonic plate, so there is very little drift between realizations.
WGS84, the native GPS datum, is tied to an average of stations around the world, so NAD83 drifts significantly over years with respect to WGS84.
Posted : 28/07/2014 4:54 pm
(@matthew-loessin)
Do not use anything other than the NAD 83(Conus) file. We had NAD83(2011) template setup first (came with the collector) and it applied a double correction. Whatever NAD83 coordinate you put in the base (i.e. 2011, CORS96, etc) will be the NAD83 coordinate system you are on.
Posted : 28/07/2014 5:24 pm
I was told some time ago that WGS84 wasn't really available for use, that it is not convertible from NAD83, in the same way you cant really change between NAD83 and NAD27 by some conversion program.
That one (NAD83 to 27)I know very well (and no it doesn't work), but since I can't really check into WGS84 I just don't know if any conversion actually works.
Posted : 28/07/2014 5:32 pm
 jaro
(@jaro)
Correct me if I'm wrong but I think what he is saying is that the coordinates in the base are from a "Here" shot and he wants the most accurate "Here" shot that he can get.
For my area that would be about -1.8' north adjustment and +3.0 east adjustment. That would get me to within 10 feet more or less, on a good day. 5 feet if I wait for waas correction before hitting the "here" button.
Not sure it would be worth the effort. That's what OPUS is for.
James
Posted : 28/07/2014 6:43 pm
The programs available for converting 27 to 83 are limited. I have found areas where it is near useless. On the other hand I work in locations where NADCON gives great results. The same is true for Vertcon and the vertical datums. It's not that the tools don't work. They just don't work well everywhere....
Posted : 28/07/2014 7:06 pm
(@sat-al)
There is no conversion from the original NAD83 to NAD83/2011. About the only thing you can do is occupy existing NAD83 original coordinates around your job site to generate NAD83/2011 coordinates and then create a local transformation. If that makes sense.
Posted : 28/07/2014 7:57 pm
Page 1 / 9
