Mushroom Monument
20 Users
(@john-thompson)
I found this today while retracing a subdivision from 1952. Plat calls for "3/4" iron rods" at lot corners. One other lot corner had a head like this, and the others that I found appeared to have heads broken off. I don't know how long it is, but it felt solid. The stem is smooth, not ribbed. This photo shows #5 and #6 rebars for reference.
I've never seen one of these before. What is this thing?
Posted : January 30, 2017 8:11 pm
could it be a tamper? for compacting alongside fence posts? I see them in hardware stores occasionally.
Posted : January 30, 2017 8:29 pm
Strange. It appears to be deformed or swaged deliberately.
I have seen similar ends on cross braced turnbuckles from girder structures, but not curved on its seating surface. I bet it's a piece of salvage that wound up doing eternity as a property pin.
Posted : January 30, 2017 8:37 pm
 jpb
(@jpb)
If it is solid, we would refer to it as a timber bolt. I can't tell from the picture. If it is, it may be threaded further down. It also may have two or three ribs under the mushroom to bit into the wood.
Posted : January 30, 2017 8:41 pm
The end looks to have been heated and rolled back to form a cap.
Posted : January 30, 2017 8:54 pm
The closest thing to that I can think of is a railroad crosstie spike. It definitely is not one of those. They do have a wide, circular top that is thicker in the center than near the edges. But, not like what is shown.
This reminds me of a subdivision with rear axles, including the lug bolts, used as lot corners. The surveyor was also the operator of a car salvage business.
Posted : January 30, 2017 8:58 pm
(@sergeant-schultz)
Around here it would be labeled as "FIP" or "IPF".
Posted : January 31, 2017 3:35 am
Timber or dock bolt. Around here you might find them near old canal locks or RR trestles, along the river in NYC or Philly. Came across a few along the Morris Canal.
Posted : January 31, 2017 4:14 am
Sergeant Schultz, post: 411672, member: 315 wrote: Around here it would be labeled as "FIP" or "IPF".
Yup that's it!
Posted : January 31, 2017 4:31 am
(@john-thompson)
Thanks, guys. Maybe I'll just go with 3/4" iron rod. Although it does look more like 5/8".
Posted : January 31, 2017 8:07 am
(@mitchptd)
Where abouts are you located? Planting Pins in frozen ground, gravel etc here can do that. Sometimes, sledgehammering an Iron pin into such a surface causes the head to mushroom, especially when using a Pjonjar or Atlas Cobra to drive it in. In winter time in Canada, planting an IP can take about 20 minutes of pounding before it goes in.
Posted : January 31, 2017 8:23 am
(@john-thompson)
I don't think the mushroomed top is from installation. There were two of them that I found that were the same shape. The top is rounded and there is a lip around the edge that is curved up. I'll try to get a better picture if I go back. Original plat is dated April, so the soil should have been soft.
Posted : January 31, 2017 8:54 am
Looks to be a homemade monument.
Maybe a large hot rivet head welded onto the end of a very old/corroded piece of re-bar?
Looks like something that would be driven into the ground to hold a parking stop or driven through pieces of cribbed timber.
Posted : January 31, 2017 9:11 am
(@kris-morgan)
Champion Paper Company made us set monuments that look very much like that. They were 1/2" or 5/8" shafts with a 2" domed head and the last 6 or 8 inches was threaded like a VERY large carriage bolt. So, we called them timber carriage bolts.
Posted : January 31, 2017 12:56 pm
Kris Morgan, post: 411753, member: 29 wrote: Champion Paper Company made us set monuments that look very much like that. They were 1/2" or 5/8" shafts with a 2" domed head and the last 6 or 8 inches was threaded like a VERY large carriage bolt. So, we called them timber carriage bolts.
http://www.portlandbolt.com/products/bolts/timber/
Posted : January 31, 2017 1:09 pm
Guest
I'm curious as from Down Under it looks like a domed headed spike (railway) in a pipe with a square top.
What's that squared partial rim just under the domed bit? Looks like a slight gap at the corner of square section.
Posted : January 31, 2017 1:37 pm
I'm curious about the 2 rebar alongside...
Posted : January 31, 2017 1:40 pm
(@scott-ellis)
Jim in AZ, post: 411771, member: 249 wrote: I'm curious about the 2 rebar alongside...
He added those for size comparison
Posted : January 31, 2017 1:46 pm
[USER=833]@Richard[/USER]
That is squared to "seat" the bolt into the wood to keep it in place and from rotating.
Posted : January 31, 2017 1:53 pm
(@billvhill)
Almost looks like a railroad spike pounded into a pipe.
Posted : January 31, 2017 2:06 pm
