Topcon Hiper+ local cell phone RTK setup is sweet, when it gets a fix.
However, typically from 10am to 2pm ish it just floats.
This seems to be true with both the private (PSC) and public (INCORS) networks.
For example, right now it says:
Common Sats 10
Initialized Sats 0
Position Type Float
What else can I try in order to get a fix?
No I do not have Glonass...
Need a fix? Check out the scruffy-looking character killing time about a block from the high school.
I always had mid-day trouble back in my Hiper days without Glonass. I think it's a lack of satellites and if you have satalittes, where they are located, bad geometry. Now that I have a system that utilizes both GPS and Glonass I don't have that problem. Pretty frustrating when you're in the wide open and need to get some work done. You can always reboot, re-set base and rover and sometimes get a fix, but you're better off keeping your RTK-ing, with that setup, to mornings and afternoons.
Typical suggestions are Clear NVRAM on the receiver (hold FN key and power cycle unit, keep holding FN till Stat & Rec go from green to Amber/Red and start flashing), raise/lower mask angle (stick between 10 and 18 degrees, changing in 2 degree increments).
There's no reason to be floating during the day for that long even without GLONASS. With a 10 degree mask, only drops to 6 satellites once during a 12 hour period. Most of the times, it's at 8 or more. PDOP < 3 the entire day.
Call Topcon tech support. There's a bug somewhere in your system.
> Common Sats 10
> Initialized Sats 0
> Position Type Float
Have you tried a static location at the same time?
Your issue is the lack of initialization which could mean that there is a communication issue. I've never used the cell modems, so I have to wonder if there is some reason the signal is being affected mid-day. Do you have UHF/SpreadSpectrum Radio abilities and have you tried using your own base station?
Is the accuracy different between float and fix?
Absolutely.
Bandwidth at cell tower is overloaded, probably kid at lunch time.:-(
:-/ that did give me a grin, ... after I got my fix (pbr ?)
The info that needs to be transmitted between a base and a rover has a limited time to get there. After that the next packet of info is coming and if the first packet hasn't got there then it gets overridden. Sometimes there is too much data and the system gets overloaded. This will become more prelevant as radios get narrowbanded. The narrowbanding will restrict how much data can be sent at one time. You may need to turn off satellites or up the elevation mask to reduce how many are available.
If you can I would try and run a test between the cell phone system and a RTK radio system. This might tell you that the cell phone system is just not getting the data through in time (not enough bandwidth).
There are also other reasons like cleaning out old data from your rover.
float = +/- meters
fixed = +/- centimeters
When did you last upgrade your firmware?
I thought we were gonna get some pics of you in a canoe!
that isn't exactly an accurate statement
yeah, i was just generalizing. close enough to know where these terms fit into the scheme.
too many unknowns to make a better error estimate
