I know you can make point lists of points to stake out in the field.
I tend to do a lot of stake to line but have to tap each line seperately after measuring the staked point. Is there a possibility to select a number of lines so after storing a staked point it automatically takes the next line in the sequence?
Can you try changing the line to a polyline or string instead? Not sure if that would work, it's just an idea.
Hey Lieven,
you know we??re on Trimble Acces but Magnet will not differ that much I think.
There??s a difference in lines and alignments i guess. Compared to cad, lines are just lines between 2 points, where alignments are polylines.
stake to the line will always be the only line selected, we can even stake points on the line before our startpoint and passed our endpoint.
We do not stake alignments, but I think you may there use the station interval there to move along your line segments, hopefully with an option to stake also the endpoints of the lines.
have a great weekend!
It doesn't work. I called Topcon Support but my?ÿ workflow isn't implemented yet in the software.
They were goign to make a ticket for further development.
