Loose levelling screw on tribrach w30sb hwb100007
2 Users
tonyduky
(@tonyduky)
  • Hello guys, i have a problem with one og the levelling screw of my tribrach. It got loose and became useless for levelling so i m wondering wich little screw of the tribrach i should use to fix this.
Thanks a l
20221023 191250
20221023 191256
ot for your help!
20221023 191302
Posted : October 23, 2022 10:19 am
kevin-hines
(@kevin-hines)
Supporter
From your description, it appears that a novice was trying to set up the tribrach, and stripped the plastic thumb screw adjuster by attempting to go past it's limits...
It has been my experience that any time you dismantle a tribrach, make repairs, and re-assemble, you need to also recalibrate the level vile to the mounting plate. Without fail, every time I made repairs, the mounting plate would get knocked around, throwing the level vile 1/4 bubble out. It would be a good idea to check the level bubble anyway if your tribrach get handled by a gorilla gripped rodman or thrown in the back seat of the survey chariot instead of being treated with the same care as your instrument.?ÿ
Good luck.
Posted : October 24, 2022 1:51 pm
