Leica GS15 vs. Leica GS14
(@amdomag)
Hi Leica Viva users!
If you are buying a Leica Viva GNSS today, which between the GS15 and the GS14 would you choose?
Thank you guys.
Regards.
Posted : June 29, 2013 2:59 am
(@evgeny)
I am planning on going with GS14; mostly because I am going to be working almost always from a network bases.
Posted : June 29, 2013 6:17 pm
I have been told that the GS08, GS10, GS12, GS14 and GS15 ALL have the same measurement internals, the difference is the housing and other features, as far as measurements go they should be the same, so it really comes down to which one fits your operation best.
SHG
Posted : June 30, 2013 3:41 pm
(@cwlawley)
It really depends on what you are doing with it. If you are running a network rover type application I would go with a GS14. If I was running an RTK application I would run GS15s. I prefer the slot-in radios. Also, do you want enough battery power onboard to run all day? Again, the GS14 holds one battery, the GS15 holds two.
Another application would be running a sounder or an underground radar-the GS15 would probably be better for these applications.
Posted : July 4, 2013 2:28 pm
