Leica data cable
sergeant-schultz
(@sergeant-schultz)
Good morning-
I'm looking for the pin-outs for the DB-9 end of a Leica data cable (TCRP1203)?ÿ I think it's 3,4 RX, TX; 5 ground, 9 positive but I'd like confirmation.
Thanks!
Posted : August 6, 2022 5:36 am
hpalmer
(@hpalmer)
on pg 1314 of the technical reference manual.?ÿ not sure if this is what you are looking for
Pin Assignments and Sockets TPS1200?ÿ
Pin assignments for
port 1
Sockets
Pin Name Description Direction
1 PWR_IN Power input, + 12 V nominal (11 - 16 V). In
2 - Not used. -
3 GND Single ground. -
4 Rx RS232, receive In
5 Tx RS232, transmit Out
Port 1: LEMO-0, 5 pin, LEMO ENA.OB.305.CLN
or on page 1316
Pin assignments for
8 pin LEMO-1
Sockets
1 USB_D+ USB data line In or out
2 USB_D- USB data line In or out
3 GND Signal ground -
4 RxD RS232, receive data In
5 TxD RS232, transmit data Out
6 ID Identification pin In or out
7 PWR Power input, 5 -28 V In
8 ATX_ON ATX on control signal, RS232 levels In
8 pin LEMO-1: LEMO-1, 8 pin, LEMO HMI.1B.308.CLNP
Posted : August 6, 2022 7:52 am
sergeant-schultz
(@sergeant-schultz)
@hpalmer I'm looking for the other end of the cable @ the DB-9
Posted : August 6, 2022 2:40 pm
mike1202
(@mike1202)
@sergeant-schultz?ÿ
same question like here?
https://surveyorconnect.com/community/surveying-geomatics/leica-1200-port-pinout/
Like written above by @hpalmer in TPS1200 Technical Reference Manual "Pin Assignments and Sockets"
http://www.geoaxxis.de/manuals/tps1200/tps1200_techref_en.pdf#G57.1210546
You just need to connect RX, TX and GND to make data connection. Positive+ is not necessary.
https://www.usconverters.com/index.php?main_page=page&id=61&chapter=0
Just if you really need "PWR_IN Power input"?ÿ for your station connect LEMO Pin 1 to DB-9 Pin 9. Other Pins wrong connected might not be a big problem. But "PWR_IN Power input" wrong connected might destroy your station. Also i don??t know any external Leica Batteries with DB-9 connectors.
I once destroyed my Laptops DB-9 connector when accidentally putting 12V from battery into the Laptop because of wrong connected wires ???.
Posted : August 8, 2022 2:59 pm
sergeant-schultz
(@sergeant-schultz)
@mike1202 Thank-you!
Posted : August 9, 2022 5:03 am
