Leica Captivate CAD files
Chief
(@chief)
Newest update has the ability to attach dog files to your Leica job. ?ÿI managed to attach one, but I canƒ??t see it anywhere in the 3d viewer. ?ÿAnyone else do this that could steer me in the right direction?
Posted : July 3, 2019 12:05 pm
squowse
(@squowse)
A few things to check -
Maybe the coords are not correct?
Can set the units on import as well.
Also there is a tickbox to convert white entities
Have you been able to successfully import it as a DXF?
Bit of a non feature for me. Never had a problem saving as a DXF.
I would never load up a received DWG directly to the logger anyhow.
Posted : July 3, 2019 1:53 pm
cameron-watson-pls
(@cameron-watson-pls)
I haven't done much other than read the update features paper.?ÿ What is the benefit of loading a .dwg over a .dxf??ÿ Will it read C3D objects like pipe networks or surfaces??ÿ If it won't do that I don't understand the benefit.?ÿ You would probably need to be using a CS35 to benefit from the C3D objects anyway because the CS20 doesn't have the RAM horsepower necessary to process those objects on anything larger than a 1/2 acre pad site.?ÿ
Posted : July 3, 2019 6:21 pm
squowse
(@squowse)
The IFC file functionality may be able to do that. Not something of great interest to me either. Whenever I have been supplied BIM models like that they have not been on correct coordinates. (for starters...)
Posted : July 4, 2019 1:37 pm
