Leica base set up w/ Trimble
2 Users
josecontreras89
(@josecontreras89)
Good afternoon,?ÿ
I was curious if anyone has had any luck using a Leica base station with Trimble gear??ÿ
My understanding was I can take a Leica base station and utilize my SPS855 as a repeater.?ÿ
I have both the base station and SPS855 set to the same channel and the Baud rate at 115200. Radio mode is set to repeater 1 as well and when hooked up I turn the radio on.?ÿ
Is there something I'm missing??ÿ
Thank for the help, have a good day everyone!?ÿ
Posted : August 21, 2018 2:42 pm
Steve Emberson
(@steve-emberson)
Did you try to set the 855 to easy ip?
Posted : August 21, 2018 2:58 pm
josecontreras89
(@josecontreras89)
Steve,?ÿ
I didn't see the option for easy IP on the 855. The only options are the following; receive, transmit, repeater 1 and repeater 2.?ÿ
Posted : August 21, 2018 3:23 pm
josecontreras89
(@josecontreras89)
Just wanted to update those who viewed this post...?ÿ
I used a SATEL 450 radio, and installed a SNR430 on the excavator. However, the Leica base doesn't send the correction on the height of the antenna.?ÿ
We set the vertical offset to 2 tenths since that was the correction on the antenna.?ÿ
Posted : August 28, 2018 9:45 am
