Jobxml to .dat With Traverse Data Types StarNet.
(@steward-souten)
Hello all
I am using a Trimble S8 total station & Starnet.
When I use the StarNet converter to convert a trimble jobxml file into a .dat file, StarNet always converts the jobxml file into a .dat file using direction data types such as DB/DM/DE.
I have been told that I need to use Traverse data types such as TB/T/TE but I was struggling to convert my .jobxml into a .dat file such that the conversion creates traverse data types in the .dat file and I was wondering if anyone knew how I could achieve this.
I have all the converters and currently using StarNet V9.
Can anyone help?
Thank you.
Posted : 13/03/2019 1:20 pm
(@squowse)
Any reason why you need to use T data lines? They are meant for quick manual input of traverses and also parcels.
Direction sets can perfectly well be used to process a traverse. They are actually a lot more versatile in my opinion, giving equal weight to all observations in a set.
I believe they stylesheet supplied by Trimble and also the StarTSC importer generate DV and M records which use "Angle right" for horizontal angle. Maybe this is what you want to see?
Posted : 14/03/2019 1:26 pm
I don't currently use the Trimble JXL converter but I have in the past. I use the TDS raw file converter. The results are very similar.
I get direction set formatted data when I do resections. I get DV and M?ÿ formatted data when I do sets of observations. I never see T type data from either converter and I don't care to.?ÿ ?ÿ
Posted : 14/03/2019 4:53 pm
(@crid54)
Have not had any of the converters generate "T" observations. When I want to have my data as a traverse, I edit the .dat file from "M" observations to traverse format. Beware that the traverse format is very specific in its order and such. It is not intuitive to me. I use it maybe once a year and have to read the manual every time.
ZI export a .dc file from Access and use StarTSC to convert. Never used a .jxl. If the .jxl converter only generates DB, DM, DE, then I don't suppose that I ever will. M and SS lines are more to my way of thinking.
Posted : 15/03/2019 7:45 am
