Javad Triumph-LS Test-Drive Offer
14 Users
Anyone planning to sign up for the two-week free test drive of the Triumph-LS? It's a pretty intriguing offer, and the purchase price is appealing, too. I'm thinking about doing it...
Posted : 13/10/2013 8:26 pm
P.S. I have no affiliation with the company; I'm not shilling for Javad, just wondering what others think of the equipment, pricing and demo opportunity.
Posted : 13/10/2013 8:28 pm
Well, it sounds as if Javad is desperate to make some sales after his involvement with LightSquared pretty much ruined the brand name.
Just out of curiosity, what would you expect the usable service life of whatever you purchased to be and how would you go about estimating what the actual service life might be with any measure of confidence?
Posted : 13/10/2013 9:47 pm
(@pat-caughey)
I am still using the now Topcon Legacy-E receivers, previously Javad Legacy-E, which were probably made in 1998-2000. I have no reason to believe that his new stuff would have less of a life expectancy.
Posted : 14/10/2013 3:25 am
(@rundatline)
This is not a new tactic. As I recall they offered some sort of deal with the Triumph several years ago. The triumph seems to have proven itself. If I had a need for additional GPS equipment, I would definitely give it a shot.
Posted : 14/10/2013 4:27 am
> ...Javad is desperate to make some sales after his involvement with LightSquared pretty much ruined the brand name.
My guess is clients in 90% of Javad's markets have never heard of LightSquared
Posted : 14/10/2013 4:41 am
(@mapman)
Tempting. 864 channels is huge. But there is just a maze of buttons on that thing! Learning curve could be challenging. 2 weeks may not do it.
Posted : 14/10/2013 7:01 am
(@the-pseudo-ranger)
Are there any pictures that show how you mount it on a pole to get survey grade results? It looks like a tablet to me. I assume you mount that part on the pole to act as the DC, and then use an external antenna up top?
As an aside, I don't like the brands of equipment that limit your options with a DC. This isn't a Javad specific problem, but all the non major players don't work with TDS. Carlson works with a lot of the non major brands, but I can't see how this could/would cooperate with another DC. It's very important to me to have compatible DC operations with my robot.
Posted : 14/10/2013 9:39 am
(@norm-larson)
That is intriguing, thanks for bringing it to my attention
Posted : 14/10/2013 9:52 am
(@t-ray)
I'm signed up! What can it hurt? Slow time of year in my area so I'll have time to play with it a bit.
Posted : 14/10/2013 1:10 pm
What is a Triumph LS?
What model is it?
Nate
Posted : 15/10/2013 2:21 am
(@george-matica)
Lights are on but there's nobody home
The "Light" is still on in these modified Triumph receivers...
LightSquared Inside
Javad's Lightsquared Solution
Javad GNSS Partnership with LightSquared
Can the TRIUMPH-LS benefit from LightSquared communication channels for receiving RTK corrections without LightSquared channels?
Posted : 15/10/2013 3:18 am
The box is the whole shebang -- it mounts on the pole like a more conventionally-shaped receiver (think Trimble R8 or a Leica GS15). The big difference is that with the Javad the data collector is an integral part of the receiver box, so this isn't something you'll be mounting on a 2-meter pole unless you're day job is with the NBA.
With the Triumph-VS -- of which the LS is (I think) a variant with a particular suite of options -- you can add an external antenna port for $300 so that you can mount the antenna higher than the user interface.
Posted : 15/10/2013 5:46 am
Ahem..."your," not "you're."
Posted : 15/10/2013 3:04 pm
Did you just "Spelling Nazi" yourself? 😀
I'm just having a hard visualizing how this is intended to work ... If that acts as a antenna, receiver, and data collector all in one, it seems like something has to give. I mean, if I kept it at a normal level of a rod mounted DC ("belly button level +/-) you'd think you'd be blocking out sats with your body and adding to multipath. And conversely, if I mount it on the top of the pole, as you pointed out, it will get nice reception, but it makes it difficult to use it as a DC.
I don't know, maybe the light will come on for me if I see a photo of someone using it, to see how it is intended to be used for survey grade work.
Posted : 15/10/2013 5:44 pm
(@r-michael-shepp)
If I were in the market for GPS equipment I wouldn't hesitate for a minute to try it.
Posted : 15/10/2013 5:55 pm
Indeed. It's an illness.
Here's one from the Javad brochure:
Posted : 15/10/2013 6:37 pm
The integration of receiver and data collector is unusual among pole-mounted receivers. (It's not unusual historically, as the Ashtech Z-12 and Trimble 4000-series did the same thing. But you wouldn't want to haul one of those around on top of a pole.) The integration seems like it'd be appreciated under most conditions, but would be a real drawback if you need to get the antenna above head level.
I did some cross-sections of a ditch last week. I used a total station, but initially thought about renting a network rover for the work. (I don't currently own an RTK receiver.) The ditch was about 20 feet wide and 9 feet deep (no water), and I had to put the prism on top of 16 feet of fiberglass rod in order to get the flowline shots. If I had been relying on the Triumph-LS for that work, I'd have been in trouble.
Posted : 15/10/2013 8:04 pm
Thanks for posting that, Jim. Seems like an interesting idea, but there are too many drawbacks for the way I like to do things. I do like the design of his Triumph-1 receivers, though, other than they apparently don't talk to TDS.
Posted : 16/10/2013 4:13 am
(@toivo1037)
Agreed. 5 Odyssey receivers still doing static work weekly. Best used equip I have ever bought.
Posted : 16/10/2013 5:32 am
