Is this possible?
12 Users
 Norm
(@norm)
I am quoting a bridge plan specification. My question: Is it possible to meet, how would you check it and with what equipment? THis is out of my scope of expertise. I'm looking for bridge staking experts. It's a little hard to read.?ÿ The tolerance numbers are?ÿ 0.002" per foot. They are all inch symbols in the spec , not foot symbols.?ÿ
bridge spec
Posted : 24/08/2018 8:36 am
 jaro
(@jaro)
I have never used a laser tracker but it is my understanding that it is possible. Mike Falk that posted here or on POB did that type of work. It is not something that any average surveyor would be equipped to do. The ones that do this type of work don't bother with boundary surveys.
James
That's cheating,?ÿ you edited while I was looking for that video. I don't know about the 0.002" but they are extremely accurate compared to what we do.
Posted : 24/08/2018 8:48 am
A good system can get much tighter that in the right environment.It is also important to note that it's no longer a 'scientific' endeavor.
Posted : 24/08/2018 11:40 am
(@tim-v-pls)
I'd definitely ask if the spec. is correct or a typo...
Posted : 24/08/2018 11:55 am
0.002 foot/foot is 0.2 feet in 100 feet. So, yes, that's do-able with digital levels and such. This is evidently a railroad bridge. And railroads, especially the high speed kind, have that kind of tolerance. It does take some special effort to achieve it.?ÿ
Posted : 24/08/2018 4:21 pm
Posted by: linebender
basically the width of a human hair. Do the specs go on to explain any hairs ?? ?ÿ ??ÿ
Posted : 24/08/2018 5:00 pm
Mark, he said those are inch symbols and your post said feet.?ÿ
While 0.2 inch at 100 ft may be possible, 0.010 inch at 5 ft is probably harder with available equipment.
And at what confidence level? "You are 95% confident it was right? We're 100% sure things didn't fit."
The spec is probably wrong, and your comment would apply if it was ft/ft, but he needs to ask.
Posted : 24/08/2018 6:26 pm
(@john-nolton)
linebender: Yes this is possible. It tell you that a "?ÿLASER TRACKER OR SIMILAR EQUIPMENT" must be used.
Do an internet search on "Leica AT402?ÿ" sometimes called the Leica Absolute Tracker AT402 and look at the spec. sheet.
I make measurements better that what they want every time I turn on my HP Interferometer (1/1,000,000?ÿ or better in 1.4 meters (or
metre whichever you like).
JOHN NOLTON
Posted : 24/08/2018 7:31 pm
Posted by: Bill93
You can purchase the equipment to meet (and far exceed) that spec for around 16K. I cant read the print in the op, but it's getting common to see numbers like this.
Posted : 24/08/2018 7:38 pm
This would be "precision alignment" that requires special equipment most surveyors do not have in shop.
Mostly used in confined areas and capable of measuring within 1/64 inch.
6 inch stainless mini rule from a prior life in machine room layout.
6in mini rule 2018082423411500
Posted : 24/08/2018 8:49 pm
(@mike-falk)
The tolerance is achievable using MODERN 3D Industrial Metrology techniques. When reviewing measurement equipment data sheets, make sure you pay attention to the?ÿreported confidence?ÿlevel of the data.?ÿ
Posted : 16/09/2018 7:57 am
 Norm
(@norm)
UPDATE
The plan is to use a FARO scanner to meet the spec.?ÿ Is that possible??ÿ
Posted : 02/10/2018 4:24 am
(@mike-falk)
The tolerance numbers are 0.002" per foot.
I suggest you look at the technical data sheet for your equipment. Part of the technical data sheet for ?ÿFARO Laser Scanners you need to consider is ranging error, angular accuracy and 3D position accuracy.
Ranging error
1mm
3mm
Angular accuracy
19 arcsec for vertical / horizontal angles
not specified
?ÿ10m: 2mm / 25m: 3.5mm
not specified
Posted : 22/10/2018 9:04 am
(@bstrand)
I'm inclined to laugh at specs like this because what are the odds of the structure settling or warping 5 or 10 or more times that much between the time the measurement is made and or after it's rolled over a couple times by a million ton train.
Posted : 10/11/2018 7:41 am
(@mike-falk)
It depends on the foundation. Our firm works on equipment with foundations that have 20 feet of concrete and pilings to refusal.
Posted : 17/11/2018 9:02 pm
