Indoor 2d floorplan
(@johnymal)
Hello i have a large floor plan building to make 2d plans is a hotel about 1000sm per floor (3 floors). What do you suggest me to make the 2d plans? I have read another thread similar to this one and many of you suggest laser scanner. I have test revo scanner but as i am new to laser scanning it needs enough time in office to be results acceptable results. Also i find some shift in long distances.
I am thinking about a convertible laptop with disto and bluetooh connectivity, i search software for laptop like this http://www.mobilecadsurveying.co.uk/laser-measure-bundle-with-lt
Do any of you have any other software solution or software similar to above to make 2d plans easier?
Posted : August 14, 2016 12:24 am
(@sireath)
Do you have a total station? if you need to just do floor plans. Instead of just a disto you can use total stations and targets to get an accurate floor plans and also pick up the linework directly as you shoot the walls.
Posted : August 14, 2016 5:29 pm
(@johnymal)
I have total station and i will use it forn control points and a general plan but the setups will be very slow..my question is if someone use the above things...
Posted : August 14, 2016 9:51 pm
(@lesirl)
We'd highly recommend the Revo and PointCab software for the creation of floor plans. It's a great combination
Posted : September 27, 2016 9:59 am
(@dan-patterson)
I've done stuff like this with a tape measure and total station. If you can figure out the wall thickness where you measure the room perimeter it will make it easier. I would think in a hotel there would be a lot of identical rooms or at least mirrored. Sometimes simpler is better. A disto can be handy for replacing the tape measure if you want to do it that way. (We didn't take many TS shots - it was mostly tape)
Posted : September 27, 2016 10:29 am
