Increase accuracy & efficiency of hard surface layout - RS150M
The3rdDimension
(@bc-surveyor)
Hello,
I recently created a video going over the RS150M and its uses for construction layout. If you do any work on hard surfaces, it's worth a watch.
Posted : June 17, 2024 8:29 pm
Jon Payne
(@jon-payne)
Another great video. If I were still doing construction layout, that would certainly be a tool worth considering.
Posted : June 19, 2024 2:42 am
lukenz
(@lukenz)
Another great practical video, I don't do this line of work but forwarded on to a colleague who would benefit.
Couple of years back went to a workshop and one presentation was from a guy working in hydro power stations was using SMR with a plate that it magnetically attached to and then you popped prism off and put a punch down the centre for sub-mm setout; they had a laptop hooked up to a 1" TS16 with special software. Same guy was also talking about laser trackers; on the fence between surveying and metrology.
The SMR, plate and punch were from https://www.metrologyworks.com/and not cheap. I also found https://goecke.de/Products/EDM-Accessories/category-280/category-282/ which seemed a bit more surveying focused.
Posted : June 19, 2024 9:47 pm
The3rdDimension
(@bc-surveyor)
Those are some very cool tools! Especially the only with the punch that fits into the center so you can hammer a dimple.
Very affordable too. I definitely wouldn't mind getting my hands on those to test out.
I've also never done any laser tracking work myself but would love to.
Posted : June 19, 2024 10:31 pm
James00
(@james00)
How does this work for setting out on a vertical surface? Wouldn't that still be a right pain to get the offsets right, unless the instrument was perpendicular to the wall?
Posted : July 3, 2024 3:52 am
The3rdDimension
(@bc-surveyor)
The target that you are shooting is perpendicular to the wall. It matters not where the instrument is
Posted : July 6, 2024 11:35 pm
