How much will this Bridge Move?
15 Users
jeff-wright
(@jeff-wright)
I'm starting a project that has a bridge on one side of it. I would really like to set grid control on the bridge because it won't be disturbed by the construction and it would afford obstruction-free views of the whole job.
However, I'm concered that the bridge may move. When I'm standing on it, If a bus drives over it,I can feel it bounce slightly up and down. It's not enough to make my total station go out of level.
It is a concrete girder bridge, with expansion joints.
How much should should I expect this bridge to move horizontally, it at all?
As an experiment, I'll set some control on it, with good ties beyond the bridge. That way when I set up on it at different times, I can get a good feel for how much it may be moving.
Thanks,
Jeff
Posted : April 28, 2011 7:47 pm
Both R Old
(@both-r-old)
Not to be mean, but I think I will go to bed now with this question plagueing my sleep...and OH WELL why not answer the question!!! Not as much as the next earthquake you get Jeff. AND are you really taking pictures under there???
Posted : April 28, 2011 7:56 pm
jeff-wright
(@jeff-wright)
It was a serious question. I'm trying to draw on the experience of the people here who have measured movement in similar concrete bridges. I'm just curious what the ballpark movement might be over the course of a day or a week.
No, I didn't take the picture. It was from the street view feature of google maps.
Thanks,
Jeff
Posted : April 28, 2011 8:23 pm
jimmy-cleveland
(@jimmy-cleveland)
Jeff,
I would move forward with your experiment, and verify the results your self. I would saturate the area with control, before construction starts. The more control the better.
I wish I had an answer to your question regarding the bridge movement, but I don't. The only thing I can offer you is that I worked for a company one time that did alot of highway work, and they did some design survey work on a MAJOR highway interchange reconstruction, and they had numerous control points on bridge overpasses. I never heard of any issues, but I did not do very much work on that job at all, as I came in on the very tail end of the survey portion of that project.
Please post your results, as I would be interested in seeing what you come up with.
Good luck!
Posted : April 28, 2011 8:51 pm
Paul Plutae
(@paul-plutae)
That's the ticket that will keep you on an even keel.
Posted : April 28, 2011 9:29 pm
eddycreek
(@eddycreek)
Control points to use for resections would be fine. I wouldn't want to set an instrument on it, unless all traffic is stopped. If it's not a robot and somebody is running the instrument and can check the backsight, probably be OK. Depends on what you are trying to lay out.
Posted : April 29, 2011 6:15 am
jaro
 jaro
(@jaro)
Two things to watch for,
Movement vertically will be much less over the bent caps
Look for expansion joints in the bridge deck to get an idea where the most horizontal movement will be. Temperature will be the major factor so time of day is important.
James
Posted : April 29, 2011 6:27 am
Frank Baker
(@frank-baker)
It will move and as James said, temperature will be a big factor. As always, the key is, how tight must your work be. I've used control similar to this but with good, tight control points off the structure to use with a least squares program for adjustment. You don't really need to occupy the off-structure points but you do need to be able to tie into them from the structure.
Posted : April 29, 2011 7:25 am
roadhand
(@roadhand)
Bridges by nature are designed to move. I would not put anything on the deck or approach slab. There should be someplace on the end of the abutments that would accomodate.
Posted : April 29, 2011 8:22 am
ctompkins
(@ctompkins)
I'm with "roadhand", bridges are designed to flex and articulate. You want solid, use the abutments. We usually drill and set disks in the top of the abutments. Works great for PERMANENT control points.
Posted : April 29, 2011 8:59 am
jud
 jud
(@jud)
It is designed to move, if it had been constructed to be rigid it would have a solid foundation to bedrock the whole length of the thing and then it would still move. The expansion joints say movement, they are there to allow movement without placing more stress on the structure caused by movement caused by loading, wind and temperature changes. Control for your grid belongs elsewhere as others have stated. Standing on long spans and having loaded trucks going by at speed, you can feel some of those bridges move a lot.
jud
Posted : April 29, 2011 10:00 am
NorCalPLS
(@norcalpls)
I can't respond to how much is too much movement for your purpose but maybe this will be helpfull. I was once working on a raised wooden platform that was tied to a building that had a big compressor or something in it. When that compressor kicked on I swore that platform was shifting an inch or more horizontally. I decided to find a stable point to monitor the actual movement from, and found that it was relativley miniscule and that the platform returned to it's pre-shift location. I decided a human's built-in motion detection system must be quite sensitive.
Chris
Posted : April 29, 2011 1:36 pm
I had my gun set up next to the Sammamish river, during the 2001 Nisqually Quake. When the shaking stopped, I turned to 0 and checked my back site and it was dead on. I was still level and still over the point and so was my back site.
I watched big Cottonwood trees whip back and forth and the water in the river slosh up the banks. I was about 35 miles from the epicenter, 6.8 is pretty big though.
Radar
Posted : April 29, 2011 1:59 pm
eddycreek
(@eddycreek)
It will move, but I also think unless something drastic happens, it returns to the same place each time. I wouldn't count on that for extreme precision, but for earthwork, should be fine. No way I'd set up on it tho.
Posted : April 29, 2011 3:16 pm
Guest
(@guest)
All bridges expand and contract. Usually one end of the span is pinned to the abutment seat. The other is allowed to slip. Around here on our bridges we see 3/4" to 1 1/2" movement in length between the morning and the peak of the heat. Really depends on the span length and the temp. It would get less the closer you get to the pinned abutment. You could calculate it fairly easy. The rate is approx the same for conc as it is for steel. Jrl
Posted : April 29, 2011 4:05 pm
jeff-wright
(@jeff-wright)
Thanks for all of your replies. As an experiment,I set a few points on the bridge that I will check from ground control periodically throughout the project. I'll keep you updated.
This doesn't have much relevance to the bridge that I was asking about, but did you know that the Golden Gate Bridge can move as much as 16 feet vertically?
Golden Gate Bridge Youtube Video
Posted : April 29, 2011 7:50 pm
Steve Boon
(@steve-boon)
The coefficient of expansion for concrete is approximately 0.00001 m/m per degree Celsius. If your bridge is 100m long then it should lengthen about 1mm per degree.
http://www.supercivilcd.com/THERMAL.htm
Posted : April 29, 2011 8:01 pm
Guest
(@guest)
mm, Celsius. What are you talking about?!
Posted : April 30, 2011 12:21 am
Steve Boon
(@steve-boon)
OK then...
A change of 0.00001 varas, per vara of original length, per 0.8 degrees of change on the Réaumur scale.
Posted : April 30, 2011 1:16 am
How much is that in Smoots?
Posted : April 30, 2011 11:22 am
