How accurate is your total station?
15 Users
(@fobos8)
Hi guys
I'm going to be buying a robotic total station soon (second hand) and I'm not sure if to get 1", 3" or 5". I mainly do smallish surveys - sites not much bigger than 100m x 100m and setting out jobs on construction sites.
How accurate is your gun and what level of accuracy do you think I need for this type of work?
Kind regards, Andrew
Posted : 04/11/2017 7:27 am
(@scott-zelenak)
Well, think of angular precision this way.
5" X 100m X 0.000 004 85 = +/- 2mm perpendicular to line of sight.
But you don't get 5 second precision until you've turned two direct and reverse sets.
For one bs and one fs (I.e. not double centering) a 5 second station is only precise to 10" under ideal conditions (and neglecting centering and leveling errors etc.) which equals +/- 5mm perpendicular to line of sight.
Posted : 04/11/2017 7:46 am
5" at 141 m (diagonal of your site) is 3.4 mm. A better instrument wouldn't give much improvement unless you can center it and the target better than that and need that precision.
Be aware, though, that the spec if for a 2-direct, 2-inverse averaged angle.
Posted : 04/11/2017 7:47 am
In order to get 1" results from a 1" gun you are going to need top, top quality tripods, tribrachs, and glass maintained in top, top condition. Even then you will see results only when the environmental conditions are just right. For 99.9% of work most of us do 1" is overkill. I really doubt that you want or need a 1" gun.
And there usually isn't a lot of cost difference between a 3" gun and a 5". So the 3" seems to be the sweet spot. That's what you see a lot of. But you will still have difficulty seeing 3" results unless you really work at it.
Posted : 04/11/2017 8:13 am
fobos8, post: 453974, member: 13166 wrote: Hi guys
First you need to identify what you mean by 1, 3 or 5 second gun. Is that least count or DIN Spec? Read careful if the math says that's a concern, which brings us to consideration 2.
What sort of layout are you doing? More particularly, what is your total error budget for the type of layout? The direction specs of the instrument are only part of the story. There's instrument and target centering, prism quality, etc. Add to that our own physical abilities. Point being that very tiny number grows quickly.
My experience says the 5 second will do most anything you describe, as long as 'setting out' doesnt include column line control. The business guy in me says think several years out and buy what works for that type of work.
Best of luck, Tom
Posted : 04/11/2017 8:20 am
(@scott-zelenak)
I should mention that my numbers above apply to the 68% or 1 standard deviation level.
At 95.5% or 99.9% the numbers would be 2 and 3 times worse, respectively.
Posted : 04/11/2017 8:23 am
(@eddycreek)
Regardless of what the specs are, get the most accurate you can afford. If you are working alone with a robot, its harder to check things, i.e check elevations with a level. Makes that fuzzy area around .04' less likely to be a measurement error.
Posted : 04/11/2017 8:37 am
(@fobos8)
okay guys - many thanks.
how accurate is your gun
Posted : 04/11/2017 9:20 am
(@kevinfoshee)
I don't do construction layout...ever. My current instrument is a 5" gun. I cover long distances with GPS and just traverse to the corners in deep canopy. I usually traverse less than 1/4 mile. I turn 1 direct and 1 reverse angles to each traverse point; but, I'm not trying to improve precision. I'm just checking for blunders.
I started with a 20" Nikon. I turned 3 direct and 3 reverse angle to each traverse point. I typically had closures better than 1:25,000 using that procedure and instrument.
It depends on your work and procedures. If you're willing to turn more angles, you can use a less precise gun. I don't know if it makes financial sense, though. When I started, I just used what the equipment I had. I was a pack mule when traversing. As a solo operator, I was carrying 2 tripods, the instrument and the range pole on every traverse. It wasn't efficient, and I upgraded as soon as I could.
Mark's advise seems good to me.
Posted : 04/11/2017 10:16 am
Guest
fobos8, post: 453984, member: 13166 wrote: okay guys - many thanks.
Mine is 3".
But Mark's comments earlier are 100%.
My TS comes from a line of 3 2 & 1 second instruments all same external looks.
Been told production would be say 3", so pull required number of instruments out and calibrated them to 3".
Next the 1". Pull enough off to fill an order and ensure they met 1" specs.
My 3" could be good for 1",but only confirmed it to 3"
But next is user input.
A 1" instrument might be reading such but due to other factors its anywhere.
Not sure which part of that answers your last question.
Posted : 04/11/2017 10:58 am
There was an article I read, concerning daily procedures for qualifying under an ASTM or ISO certification, which called for three direct and reverse observations to be made within the din specs by the manufacturer. This may have been cribbed or paraphrased from a certified publication.
Is something like that true ?
Posted : 04/11/2017 11:51 am
(@conrad)
Hello Andrew.
buy a leica 1ƒ? instrument if you can afford it, and never have to be worried about the direction readings it is spitting out
We own 3ƒ? and 5ƒ? instruments and I would have liked one of these to be a 2ƒ? or 1ƒ? model for construction layout.
Posted : 04/11/2017 11:05 pm
(@conrad)
For the modern leica unitƒ??s Iƒ??ve tested this isnƒ??t true. You get the manufacturers stated accuracy straight up by turning angles in one face. Turning 2 faces makes little difference. You may as well just average 2 pointings for the good it will do with these instruments.
For one bs and one fs (I.e. not double centering) a 5 second station is only precise to 10" under ideal conditions...
For the units Iƒ??ve tested this doesnƒ??t improve by using both faces. So this is not a useful rule.
Scott Zelenak, post: 453981, member: 327 wrote: I should mention that my numbers above apply to the 68% or 1 standard deviation level.
The units Iƒ??ve mentioned do not produce normal distributions, so these numbers do not apply. The distribution of angular residuals from my adjustments are U-shaped and have no tail. so if you calculate 3-sigma it means nothing.
Iƒ??d be wary of making assumptions about surveying instruments specifications based on perfectly distributed randomness. I donƒ??t see it from modern leica instruments at least.
Posted : 04/11/2017 11:39 pm
(@richard-imrie)
In metric terms I understand that at around 206m, the order of 1", 2", 3", 5" equates to 1mm, 2mm, 3mm, 5mm. We just do engineering surveys and have 1" instruments, and the main original reason for that was so that the accuracy of the instrument couldn't be challenged (unless someone wanted to dig deep and go for the 0.5" or better). Having said that, to date nobody has challenged our equipment, but it is comforting to do a bit of control with the TS and then check it (or vice versa) with optical level and get 1 to 2mm of vertical difference and then be able to muse that that is what the TS should be able to achieve.
Posted : 05/11/2017 12:04 am
Guest
Conrad, post: 454044, member: 6642 wrote: For the modern leica unitƒ??s Iƒ??ve tested this isnƒ??t true. You get the manufacturers stated accuracy straight up by turning angles in one face. Turning 2 faces makes little difference. You may as well just average 2 pointings for the good it will do with these instruments.
I use my Nikon similarly. I was bought up through Theodolites and when EDM arrived believed F1 F2 was the ONLY way to achieve accuracy.
I decided sometime to trial F1 only taking just as much sighting care as I did with 2 faces.
Closures never suffered and its very rare to read 2 faces now.
You need to know your instrument and watch your procedures. Good results follow.
Posted : 05/11/2017 12:40 am
