Hiper Lite + switching from base to rover
dmyhill
(@dmyhill)
My rover is in the shop, and I want to run the base as a network rover.
I have attempted to set it as a rover in PC-CDU, but it doesnt seem to work.
Anyone do this regularly? Is there a program I can run on my FC2500 to do this in the field?
(I run Carlson SurvCE)
Posted : May 30, 2012 1:36 pm
matthew-m-filus
(@matthew-m-filus)
MODEN-TPS is what you are looking for. Should be able to download it from the TOPCON support site.
Matt
Posted : May 30, 2012 2:34 pm
dshearon
(@dshearon)
No changes to settings should be required for network operation. Should be able to just clear NVRAM then switch the bluetooth device in the rover profile.
Posted : May 30, 2012 3:33 pm
dmyhill
(@dmyhill)
That is what I thought, but no go.
Posted : May 30, 2012 8:11 pm
dshearon
(@dshearon)
Is the base range limited? Hiper Lite +'s came standard range limited and that might affect your connection. You can check this in PC-CDU by going to tools > options and find rtk distance. If anything other than 511 then it is range limited.
Posted : May 30, 2012 9:31 pm
Martin Paquette
(@martin-paquette)
The method we use is as above, to do it with TPS Modem, a free applet. Works sort of like PCCDU. I saw an installed field utility recently on some handheld device but forgot where. Too bad the units don't just have a switch right on them for this one, since it's something I seem to need to do frequently.
Posted : May 30, 2012 10:07 pm
dmyhill
(@dmyhill)
I will have to check this. Our Rover has a pretty long range, but I have never checked the base.
Posted : May 31, 2012 9:16 am
