Help with T3 legs
8 Users
I got a T3 instrument but don't have any legs for it. I got the top plate of the legs that the instrument sits on but the wooden legs and spikes are missing. This is not used in the field. Have found some legs but out of my price range.Can anyone tell me of a set of legs that will hold the instrument or where I can get the wood poles and spikes. Thank you very much.
Posted : May 26, 2016 9:56 am
T3, you mean a Wild Heerbrugg inst, I'd guess?
You can pick up a set of legs, non Wild brand, easily. For around $ 100.00
Here is a green set, but some of the parts are missing, at the head.
http://www.ebay.com/itm/Vintage-Antique-Army-Military-Survey-Tripod-Wooden-Steampunk-Camera-Industrial-/391464842892?hash=item5b251f768c:g:-ugAAOSwixtXQ63~&apos ;">Antique Green Military style legs
And, this is a good heavy set.
http://www.ebay.com/itm/TOPCON-HEAVY-DUTY-SURVEYING-WOOD-TRIPOD-/351741931991?hash=item51e573f1d7:g:S8sAAOSwSWJXRJ6C&apos ;">Topcon Heavy Duty, Maple Legs
Just search on ebay, "Survey Tripod".
http://www.ebay.com/itm/Heerbrugg-Wild-T3-Precision-Theodolite-Survey-Scope-24x-40x-Eyepiece-Illuminator-/322098341396?hash=item4afe8ea614:g:jFgAAOSw--1WtP89&apos ;">And, here is a Wild T3 on ebay.
I think the T3 is overpriced, but I don't know alot about them either.
Not really knowing what you plan to do with it.. is this for indoor display?
Anyway, MOST survey companies are going to RTK and Post processed GPS, and no longer have need of the older OPTICAL theodolites, because they don't hook to a data collector, and transfer the data via wires.
Maybe you can find what you need.
Posted : May 26, 2016 10:15 am
stephen-ward
(@stephen-ward)
The T3 uses a larger tripod head than normal due to the size of its base, but for display purposes a standard tripod works fine. Just make sure that the clamps/screws are tight if it's an adjustable tripod.
Posted : May 26, 2016 10:35 am
norm-larson
(@norm-larson)
As you undoubtedly know already, a T3 will overhang a standard tripod, below is my model of a GST20 and a GST30 tripod sitting side by side. This really shows the size difference
http://www.imgtree.net/&apos ;">
To me the difference looks too great to just bend other leg parts to fit as the top is so wide. I hope that I am wrong and if you find a set that works, please post
Posted : May 26, 2016 10:39 am
larry-scott
(@larry-scott)
Or in a trophy case next to your Curta and Berger.
Posted : May 26, 2016 10:49 am
john-nolton
(@john-nolton)
If its NOT used in the field where do you use it?
Don't be frugal buy the correct tripod.
JOHN NOLTON
Posted : May 26, 2016 4:23 pm
[USER=106]@Dave Ingram[/USER]
Maybe Mr. Ingram will chime in...
https://surveyorconnect.com/community/threads/i-made-a-tripod.161717/
DDSM:beer::beer::beer::beer:
Posted : May 26, 2016 4:31 pm
I got a standard tripod I want to get one so the tri bracket won't hang over.
Posted : May 26, 2016 6:22 pm
The legs I found cost more than the T3.
Posted : May 26, 2016 6:28 pm
pmoran
(@pmoran)
Look at the NEDO brand for a straight leg with the larger head. I used T3s exclusively for 12 years the the Wild tripods were great but I never trusted a slip leg- the name itself tells you why.
Posted : May 27, 2016 9:08 am
