GNSS Radio Repeaters in Extreme Heat, a successful story
5 Users
(@mark-silver)
Just in case you need to survey in the desert, in the summer, with a repeater.
A customer just finished a large survey, 18 days in the field. Daily temperatures were over 115 F.?ÿ
They tried my shade umbrella trick:
ReflectiveHat
But the repeater would shut off midday, even with the ADL Fan cage running full tilt.
They came up with putting the repeater in a water cooler with a one gallon milk jug filled with water frozen solid:
InBucket
with a notch cut for cables and the radio wire tied to the top in case water jug leaked.
CalbeWay
The entire setup looked like this:
RepeaterSetup
At the end of each long day the ice jug was still 1/2 solid.
They were broadcasting full GNSS with CMRx, 9600 baud, Satel format with no FEC if you are wondering.?ÿ
File this away for the next time you have that random job in hell.
Posted : September 3, 2019 12:13 pm
Thnaks, Mark...
We used a reflective blanket in Abilene, TX where it was HOT, but this looks like a better idea.?ÿ
Here is a similar idea for A/C in a small plane...you basically put ice in a cooler and then a fan brings in air, blows it across the ice, and then back into the cabin.?ÿ
https://www.sportys.com/pilotshop/arctic-air-portable-air-conditioner-30-qt-single-fan-12-volt.html?___SID=U
Posted : September 3, 2019 1:46 pm
@john-hamilton
Kinda like a swamp cooler...
Posted : September 3, 2019 1:55 pm
(@gene-kooper)
Posted by: @mark-silver
As they say Mark, necessity is the mother of invention!?ÿ Thanks for sharing.
Posted : September 3, 2019 2:58 pm
(@ridge)
I've figured out I'm TOO OLD to go to hell.?ÿ 115 degrees I couldn't survive even if the GPS stuff was working great.
Posted : September 3, 2019 5:41 pm
