Following the 1891 Surveyor Today
Today's field work involved retracing various lines of a 1000 acre tract originally surveyed in 1891 that adjoins a larger tract I'm surveying. I mention it because it provides an example of the persistence of certain trace evidence.
The calls of the portion of the boundary of interest as set forth in the original deed of conveyance were as follows, running from a corner on an original land grant line:
[pre]
N45°E, 3946 varas to rock mound from which:
- a Live Oak 4" mkd X bears S55-1/2°W, 11 varas,
- another 10" mkd X bears N87-1/4°W, 20-4/5 varas;
Thence S45°E, 239 varas to rock mound from which a Live Oak 8" mkd X bears S83-1/2°E, 11-1/5 varas;
Thence N88-3/4°E, at 195 varas corner of rock fence ....
[/pre]
(For the non-Texans, our statutory vara is 33-1/3 inches, 36 varas = 100 ft.)
On the ground, there is a wire fence that I would guess is probably 1950's or 60's vintage, with some scattered traces of an older fence along it, i.e. scraps of much older wire ingrown into trees and a few posts that appear to be much older than those in the fence. The courses of the fence resemble the 1891 surveyor's description as far as the relative angles between the three courses go and the distances were close, between the fence posts, i.e.:
[pre]
Record Actual
239 vrs. 239.390 vrs.
195 vrs. 196.480 vrs.
[/pre]
On other work that the 1891 surveyor had done in the area in 1889, the chaining was running long by a scale factor of about 1.0048. That is, a line he had reported to be 2283 varas in length was found by resurvey to actually be 2294.04 varas long, which is quite similar to the average excess in the two lines mentioned above, i.e.:
[pre]
(239.390 + 196.480)/(239 + 195) = 1.0043
[/pre]
I was reasonably sure that I had identified the corner of rock fence to which the 1891 surveyor gave a passing call. I set a rod and cap marker on the line of what appears to me to be the base course of an old rock fence where it intersected the line of the older wire fence. The rod and cap falls on the West side of one of the older cedar posts in the fence.
Backing in from that point, 196.480 vrs. and 239.390 varas along the wire fence took me to another corner of the fence
This at first impression appeared to be in the vicinity of the corner described by the 1891 surveyor as:
[pre]
Rock Mound from which:
[/pre]
However, a quick look turned up only a suggestive scatter of rocks, no identifiable mound and no candidates for the two bearing trees. In that area, I'd expect Live Oaks to have grown about 9 inches in diameter since 1891. The 4 in. Live Oak could have been killed by the marking. It was a poor choice for a bearing tree and I did not think that any trace of it could be found. However, the 10 in. Live Oak should have at least left a stump hole.
In the vicinity of the corner, the soil condition was a gravel bound up with a natural cement that made a very hard soil into which a probe rod could not be readily advanced. So it only required a rough tape and compass measurement to get close enough to the position of the bearing tree to find the stump hole with a probe at the approximate center of a low mound. Surrounding the hole, the probe rod refused to go much more than about 3 or 4 inches into the soil. At the stump hole, I could run it down about 16 inches without extraordinary effort in about a 12 in. radius region.
I set a rod and cap at the center of that stump hole and found that the bearing and distance from it checked the cedar fence corner post within less than 1 ft. Given the somewhat lower accuracy of treating the center of the hole as the center of the former bearing tree at the height of the mark to which the distance and bearing would have been taken by the 1891 surveyor, I don't consider that discrepancy to be significant.
Posted : August 2, 2014 10:42 pm
Following the 1891 Surveyor Tomorrow
Tomorrow's work will involve looking for the stump hole of the 8 in. Live Oak bearing tree at other corner. When I was there earlier today, all I had in the way of evidence was what looked like a scatter of rocks near the angle post in fence. So I didn't spend much time following up the theory that the post perpetuated the mound, preferring to wait until I had the rock fence located.
Tomorrow's work will also involve some more substantial bearing trees on another line that ought to remain in place if the feral hogs haven't intervened. It's the classic case of working a puzzle with the object of fitting in a few key pieces that make the rest much easier to assemble.
Posted : August 2, 2014 11:39 pm
NotSoMuch
(@notsomuch)
I do enjoy reading your tales from Texas.
Boundary retracement was my favorite aspect of the profession.
Good luck -- and yes, I realize luck has little to do with the level at which you practice.
Jeff
Posted : August 3, 2014 7:42 am
> Jeff
There is a saying that "Good preparation makes good luck"
Posted : August 3, 2014 8:26 am
mark-paulson
(@mark-paulson)
Hello Kent,
Long time no see. I would say you are looking a little old, but your picture kind of looks like looking in the mirror.:-) That post reminded me of surveying near Notrees and searching for a section corner, 2" iron pipe set in 1901, that had actually been moved my the sand dunes and was about 4 feet deep. the Schonstedt keep getting a weak signal and I finally found it, but a dune had pushed it about 5 feet out of the location. One of the crew members asked my why I kept digging. I advised him that it was the only way to be sure that it wasn't the corner. Persistence always pay off. When I was the survey manager at a larger engineering firm, one of the principals asked my why we had to make so many trips to the field to get a survey done. He said that when he was running the department that most boundary surveys only took one trip. I replied, "that I could tell by looking at them." I don't think he ever figured the response out.
Best regards
Posted : August 3, 2014 12:21 pm
Buzzard Following the 2014 Surveyor Today
I finally had to tell him that Mr. Cash would not be riding his Harley past the ranch today.
Posted : August 3, 2014 11:43 pm
Nothing good to eat here. You would have to pressure cook my tough hide to make a meal for anything. Although from what I've seen I'm pretty sure he's not a "picky" eater..:pinch:
I think he's got his chops set on a lone Texas surveyor that succumbed to the heat while digging up persistent trace evidence...
Be careful out there in August. It would be a shame if you final act of humanity for posterity was to feed the indigenous population! 🙁
Posted : August 4, 2014 5:48 am
Did a Buzzard survey once.
Nice fellow, actually. He had purchased 10 acres of rural land to escape to on weekends so he could attempt to ignore the rat race in KC.
Posted : August 4, 2014 6:26 am
I did a "Buzzard" survey last week
The old goat followed us around in a golf cart on his manicured 45 acres. That old fart would bitch about paying for anything....
Posted : August 4, 2014 7:11 am
Actually, the weather has been lovely, with highs in the low 90's and fairly dry. I'll post photos of the two trees I found yesterday on another line once I've ciphered a couple of things out.
Posted : August 4, 2014 7:45 am
