does Topcon have a multipoint option?
2 Users
CL_H
 CL_H
(@cl_h)
im recently working with a Topcon device running on the Topconfield app.
i am still kinda figuring the device out but for the life of me i can't find the multipoint tool
i normally work with Leica and for underground Infra measurments. and its an almost indispenceble tool
does anyone know where it's located?
i mean if a cable or tube splits in 2 you can select both strings and measure them at the same point.
Posted : December 4, 2025 9:59 am
Topic Tags
leegreen
(@leegreen)
Yes - it is called Multiple Codes
Posted : December 6, 2025 10:49 am
CL_H
 CL_H
(@cl_h)
@leegreen
thanks for your answer but it seems like we are using different verslons of the Topcon field app
because i don't recognize that screen layout
maybe its because i'm using a version running on an android device instead of a certified surveying field book
i am able to create different codestrings but and i can put multiple attributes.
still no succes on the multi point though.
every walk through i find online seems to be with the different layout as well. even on the Topcon guides page i can only find the other version ones.
ill try contacting support again (they still havent reacted to the earlier question)
Posted : December 10, 2025 10:50 am
