Defining expected accuracy of static GNSS Survey
(@totalsurv)
I would like to define for a client the accuracy that can be expected from a static GNSS survey. Would it be sufficient to define in terms of Error Ellipses at 95% CI and would it be wise to include equipment specifications also? My errors ellipses from Survnet are usually around 0.005 major & minor and 0.020 elevation.
Just curious as to how others define the accuracy achievable.
Posted : 10/07/2019 12:25 pm
Use the manufacturer's spec sheet:
Here is the sheet for the R10
static
Posted : 10/07/2019 1:14 pm
You have to know the question before you provide the answer.
Absolute or relative positions?
Environment?
Time constraints?
Density and configuration of network?
The list goes on....
Posted : 10/07/2019 1:30 pm
 Norm
(@norm)
Precision to be precise.?ÿ
Posted : 10/07/2019 2:49 pm
(@totalsurv)
Posted by: thebionicman
Environment?
Time constraints?
I think a reasonable expectation of accuracy could be stated with the caveats above.
Posted : 10/07/2019 10:54 pm
(@totalsurv)
Posted by: linebender
Not much good without accuracy as well. You can precisely hit the wrong point many times.
Posted : 10/07/2019 10:56 pm
