creating cut sheet with TDS foresite
2 Users
(@david-york)
Has anyone created a cut sheet in foresite? I can't figure out how to get the points into the report. Any help is much appreciated. David.
Posted : April 5, 2011 7:46 am
(@mack-chete)
When you stake the points in the field, you have to store the set point in the stakeout screen. Then download both the .job and .raw files. Next, go to the Job pulldown menu, go to Cut sheet report, and it should give you several options on the left side. Once you select the parameters that you wish to use, you can hit edit report to get a printable version. Hope this helps. I think the secret is to store the points in the field.
Posted : April 5, 2011 12:31 pm
(@david-york)
Thanks Mack. I used the stake list of points and then shot the hub using store SS on the offset. I think I should have done it differently in the field.
Posted : April 6, 2011 5:29 am
