We have a Bosch 36V 1" SDS-Plus Rotary Hammer 11536VSR and a gas powered Ryobi. I have only used the Bosch once and it seems to be about 90% of the Ryobi. I noticed in another post that some are using a similar 20 Volt DeWalt Hammer Grill. I did a little research and DeWalt has a very similar 36 Volt hammer Drill also. The DeWalt is not as costly as the Bosch.
Does anyone have experience with the 36 Volt DeWalt?
If you mean he 20v Dewalt, yes, I have. It's fine. Obviously the battery life is much less. We needed to add to the fleet just last month, and we added the 36v Bosch.
The Ryobi, which I have also used, just isn't available any more, is it? If it is, I'd sure like one.
Yeah. I have two and if you want either one, you'll need to pry it out of my cold, dead hands. I consider it to be a fundamental tool for land surveying in Central and West Texas. It gets used on virtually every project, whether it's drilling:
- a 3/8 in. hole in a concrete curb for a spike and washer control point,
- a 3/4 in. hole in rock or concrete into which to grout the stem of a tablet (using the same 3/4 in. bit to countersink the tablet a bit),
- a 5/8 in. x 20 in. hole in rock to set a rod and cap monument in,
- a 3/4 in. hole in rock or caliche to drive a 48 in. PVC "lath" into
- a bunch of 3/4 in. holes in asphaltic concrete pavement to break the crust,
it's all good. Mine are now 23 years old and still running great.
