Civil 3D Survey Figures Missing?
5 Users
(@chevisk)
Hopefully someone can help me out here. I am working on a large scale topo and I noticed my Survey Figure lines were not there anymore. I have been working on this for about 3 days and the Figure lines are part of the topo as break lines. Somehow they disappeared on me and I have no idea where they went. If I go through the database where I processed the files and re-inset into DWG I see them pop up and then they go away within a matter of seconds. I have been using civil 3d for 2 years and have never had this happen. Any suggestions?
Thanks
Posted : March 17, 2014 8:32 am
(@wa-id-surveyor)
What version of Civil3d?
We had a similar thing happen to a rather large topo drawing using Civil3d 2010. We have to revert to a backup file to get things back to normal. We opened a ticket with Autodesk and they basically said to upgrade (surprise surprise). We already had the upgraded version but hadn't yet implemented it. Since then, we have upgraded and haven't had a reoccurrence.
Posted : March 17, 2014 11:25 am
(@davidgstoll)
CK,
Post your drawing on the Civil 3D Forum. One thing to check is the Layers in the Figure Styles.
Dave
Posted : March 17, 2014 4:34 pm
(@chevisk)
We are using 2011. I have been using 2011 for 2 years and have never had this happen. After doing some research others have had the same problem. Its like there in there just not showing up.
Posted : March 18, 2014 2:09 am
(@davidgstoll)
CK,
I haven't seen this problem. Are your breaklines still affecting the surface? Have you run an audit on the drawing?
You really should post this on the Civil 3D Forum.
Dave
Posted : March 18, 2014 3:02 am
(@chevisk)
Yes they are still acting as break lines you just cant see the line. I have ran an audit and that did not work. My auto save and Bak DWG saved after this took place so neither one of them shows the figure lines. I will post the DWG today on the forum to see if anyone can get them back.
Posted : March 18, 2014 3:24 am
I have very limited experience with C3d, and only a users experience with computers, but I'd be looking into a hardware problem with the video card or processor. Sounds like it is running out of memory. Have you tried opening the drawing on another computer?
Posted : March 18, 2014 5:04 am
(@exbert)
Have you tried closing down C3D completely? Or maybe restarting your computer?
Posted : March 18, 2014 9:24 am
