I have several 2 meter rods that I use for static GPS at least once a week. When I pulled them out yesterday, the level bubble had doubled in size and was basically the size of the whole glass. I have never seen this happen. Is there a way to fix this?
Get a new bubble. sounds like some of the fluid leaked out or something. I have a couple old ones laying around here that look like that. I wouldn't trust them.
I bought some 8 minute bubbles a couple months ago from http://www.baselineequipment.com/
They are an advertiser on Surveyor Connect and at the recommendation of my buddy Scott Freshwaters, I purchased from them. Search on the site or just call Jim at Baseline.
http://www.baselineequipment.com/vial-and-vial-assembly-replacements
What the manufacturers don't publish is the hole spacing dimension; that would be especially helpful when trying to fit 'their' bubbles to 'your' poles. I had to improvise by drilling new holes in my bubble holder on my pole to make the new bubble fit, and also shorten up the screws a little.
I'm pretty sure that when I've swapped out SECO bubbles on SECO poles, the hole patterns were identical. When buying a pole, checking to see if the manufacturer offers different bubbles with different sensitivities for it is always a good idea.
Yes, good idea. Two of the four prism poles I have are probably 20+ years old, still good shape, rugged and reliable. Those are the two I bought replacement bubbles for. I really have no idea what brand they are and because I wanted more sensitive (8 minute instead of what I think were 40 minute vials) replacements, I knew that getting any replacement to fit might take a bit of work. Which is why, if the hole spacing was published/available, I may have chosen a different replacement instead of the ones I ordered.
I did consider this source with the thought of removing the existing vials and gluing on the new ones, then the mounting problem would not have been an issue.
http://www.geier-bluhm.com/index.php?cPath=59_40
