Carlson SurvPC running a Topcon GT1001 using Leica -34.4 Prism
Ron Ayers
(@ron-ayers)
If you are running this set up be aware that when you add the Leica prism -34.4 to the data collector it will switch the total station to shoot the prism as a -34.0. Anyone else with this problem? Carlson told me I'm the only one and they will not fix it.
Posted : April 14, 2022 7:34 am
leegreen
(@leegreen)
Topcon Magnet field will properly use the pc of -34.4mm.
I think Carlson's support is telling you that most instruments really can't measure less than a millimeter in precision so why bother with settings in sub-millimeter.
Posted : April 14, 2022 10:12 am
Ron Ayers
(@ron-ayers)
Yes, Topcon Magnet recognizes Leica -34.4. When running Carlson it rounds it to -34.0 on the gun. 2ppm is what the gun accuracy in horizontal.
So, I understand the 0.0013' is not enough to worry about. But they take it in to account for Leica why not TOPCON.
Posted : April 14, 2022 11:30 am
Norman_Oklahoma
Posted by: @leegreen
I agree. Also- those stickered offsets are nominal. The actual offset of any individual prism unit will vary. Kind of a bummer that this software won't carry more decimal points, but only Leica quotes offsets to the tenth of a millimeter in any case.?ÿ ?ÿ ?ÿ ?ÿ?ÿ
Posted : April 14, 2022 11:42 am
And when you get to the fraction of a millimeter, you'd better be pointing the prism at the instrument for every shot, because you can easily pick up a mm or two with mispointing on a -30 or -34.4 mm offset.
Posted : April 14, 2022 12:40 pm
Ron Ayers
(@ron-ayers)
Is there another software that rounds to the nearest mm?
Posted : April 14, 2022 1:51 pm
