Carlson Surveyor+ external power
 JB
(@jb)
Anyone know if there is an external power pack for the Carlson Surveyor+?
I'm looking for something that would use regular batteries to get a job finished when the Li goes dead.
TIA
Posted : May 14, 2014 6:30 am
(@ladd-nelson)
There is not a manufacturer approved external power solution for the Surveyor+ that I'm aware of. However, power specifications for the Surveyor+ state:
>Runtime up to 16 hours
>Two battery slots
>Runtime up to 32 hours with two batteries*
>*Actual runtime depends on application and configuration
There is also a travel charger kit that can be used to charge a spare battery:
Travel Charger
Charges spare battery, includes Cigarette Lighter Power Adapter. LED indicators for power applied, charging, charge complete. May also be used with standard AC Power Supply.
Posted : May 14, 2014 6:55 am
(@scott-ellis)
That extra battery is really nice, I have yet to have the data collector go dead in the field on me, even after some 8 hours or longer days. With some of the past data collectors I used, I would be lucky to get 4 hours out of them. I know of some of the older Carslon they have a charger you could plug into a battery and connect to the date collector.
Is that what you are looking for? Its not for the Surveyor Plus however.
http://www.hayesinstrument.com/cgi-bin/webc.cgi/st_prod.html?p_prodid=2525
I have only had to use the cigarette lighter power adapter once, and that was because I forgot to put the date collector on charge after a long weekend.
Posted : May 14, 2014 7:11 am
