Carlson SurvCE
2 Users
(@amdomag)
Hi guys!
I am relatively new to SurvCE. I wonder why IR fast and Level Checking are not supported with my Leica Flexline.
Thank you so much.
Regards.
Posted : January 22, 2012 12:20 pm
(@ladd-nelson)
I can't provide you with a reason why these routines are not supported in your Flexline equipment but I have submitted a request to the Carlson programming team to see if these features can be added for a future version of Carlson SurvCE.
Ladd Nelson
Posted : January 23, 2012 2:16 pm
(@amdomag)
Thank you so much Ladd for the information. I know that it will be supported very soon.
Cheers!
Posted : January 23, 2012 6:31 pm
(@amdomag)
Please allow me to take this opportunity to ask you regarding the coding possibility in SurvCE to connect current shot to a previously measured point of different code.
Thank you so much Ladd. You're the man.
Regards.
Posted : January 23, 2012 6:38 pm
(@ladd-nelson)
I would suggest using the "Join Point" code as found under SurvCE -- File tab -- Feature Code List -- Special Codes. Presuming the Join Point code is JPN, shots collected in the following fashion:
>PT1 = BC
>PT2 = BC
>PT3 = BC
>PT4 = CL JPN3
>PT5 = CL JPN2
>PT6 = CL JPN1
would/should yield something similar to:
In my example, both the BC code and the CL code were configured to produce linework between the successive BC codes and CL codes, respectively.
Ladd Nelson
Posted : January 24, 2012 5:44 am
(@amdomag)
Thank you soooo much Ladd!!!!
Regards.
Posted : January 24, 2012 7:09 am
