FCB+1
FCB
FCB
FCB+2
For some reason Carlson thinks i want to fit a curve between these shots but what I want is straight line segments. Any help welcomed.
DANEMINCE@YAHOO.COM, post: 382528, member: 296 wrote: FCB+1
FCB
FCB
FCB+2
I've never seen the + sign used in line coding. Could this possibly be the reason?
Did you check your special codes.
I have set the special code fro begin line as +1 and end line +2.....there must be a check box someplace that makes the software think I want to fit a curve......but i have not issued a curve command?????
DANEMINCE@YAHOO.COM, post: 382652, member: 296 wrote: I have set the special code fro begin line as +1 and end line +2.....there must be a check box someplace that makes the software think I want to fit a curve......but i have not issued a curve command?????
I was not able to replicate the behavior. Would you be willing to send me your *.FLD file and the *.F2F values (Code Table Settings -- SaveAs) along with the four sets of points and their descriptions? The Carlson version number/build (Help -- About Carlson) might also be useful information.
lnelsonATcarlsonswDOTcom
Lon was very helpful. + 0 and -0 did the trick I am using the Autocad engine for 2016 Stand Alone 02/05/16
